Question about SanDisk Sansa e250 MP3 Player
Sandisk e270 says dree up space 6gig
Plug e270 up it will not sync. unplug it ti say not enought space on database free up 6 gigs
  • 54 Answers
Simply put it into recovery mode. to do this plug it into your computer and push the hold button till the ornage is showing. next push and hold the record button as well as pushing and holding the power button. if you do this correctly it should free up the space. heres the forum link if your still confused. http://forums.sandisk.com/sansa/board?board.id=e200
Best of luck! i hope i help : )
Posted on Feb 13, 2008
When I turn it on, the Refresh database screen comes on but never complete. No matter how many time I reset the unit, it seem to be jammed to that screen. How should I fix the problem?
I've run into this issue before with my SanDisk Sansa the issue is typically either you are running close the to the size limit or there are some large files that have corrupted. I've fixed by completely removing all the files from the device. Please keep in mind the below steps will remove all the music from your device and this will need to be synced back over:
1. Connect the SanDisk to a PC via the USB cable
2. After this is connected it should show up as an additional drive in the My Computer window (possibly E or F, but this varies).
3. Expand the corresponding drive letter until you get to where your music is stored.
4. Delete all the music folders/files
5. Disconnect the SansaDisk from the computer and then power it off and then back on.
The Database should refresh properly and then you should be able to begin syncing items back to the device (I would suggest syncing items in small blocks to prevent any corruption from occurring again). If you encounter any problems, let me know.
Nov 27, 2009 | SanDisk Sansa e270 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
CANT FREE UP ANY SPACE ON MY SANDISK
The only thing to do for this error is goto My Computer/Computer and right click on the Sansa player, choose format.  Select Quick format.  It will delete all data but at least the player will work again.
Jan 24, 2009 | SanDisk Sansa Fuze MP3 Player
Format my Sansa e270
1 way is to let windows re-format it.
Plug player into usb of computer.
open up mp3 drive. click on tools.
have windows re-format it.
2. Download firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1449
download the new firmware and check the box that says reformat
data area.
Jan 04, 2009 | SanDisk Sansa e270 MP3 Player
Stuck on refresh/black screen
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 22, 2008 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player has only 79 songs and 3 GB used
You may have some corrupt data on the device.
It sometimes creates the wrong file allocation and gives you an incorrect representation of the free space.
Try formatting the device in My Computer to erase all of the information and start over.
My Computer>Device Name(e270)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | SanDisk Sansa e270 MP3 Player
Sansa 280 with 8 gigs
The message says it needs 6MB of space for the MUSIC DB ( the database, the artist names, etc).
You need to delete some of the recordings off of your device to free up some space.
You can manually delete the files while connected to your computer from My Computer>Device Name (e280)>MUSIC Folder.
Best of Luck.
Nov 09, 2007 | SanDisk Sansa E280 MP3 Player
Sansa Sandisk E270 - Refreash Database
I found that the unit needs to be turned on first then plug it into your usb port.
Dec 20, 2006 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
