Loose Parts?? Parts have come loose inside the printer. Looking inside,from the front, there's a thin plastic strip that's connected to a post on the back wall. The other end of the strip is flapping in the breeze. Also, there's a spring, one end of which seems to be connected to the same post as the strip. The other end is just hanging down.
  • 2 more comments
  • Anonymous Apr 25, 2008
    The encoder strip came loose on both ends on my Dell 720 ink jet printer. How do I hook it back up?
  • IreneC Apr 30, 2008
    The same thing happened to my Lexmark Z55- it came right out onto the floor when I shook and turned it upside down to get something out that had fallen in- (lesson learned).
    I don't know what to attach it to on either side. I have directions for getting it on the back of the printer cartridge (thank you, Silly Girl) but not either side.
  • Cheryl Cassidy
    Cheryl Cassidy Nov 24, 2008
    the encoder strip has come off my f80 and can't figure out how to get it back on - it is not torn, etc.
  • Chris Lemke May 11, 2010
    New printer time... period.
  • 168 Answers
Sounds like the Encoder Strip, but without the Brand Printer and model number, I cant be 100% sure.
If it is the encoder strip, this is what the printer uses to tell where the carrriage is located at. Without it, the printer won't work.
You can try to repair but it will take a little time. 1st make sure that the encoder strip isn't torn at either ends where the spring goes in.
The encoder strip goes from 1 end to the other end, and it also goes through a small opening in the back of the carriage unit.
If you have a make and model, I could be a little more specific.
Good luck.
Posted on Feb 05, 2008
Acer aspire laptop screen problem.looks like ink burst behind screen
Suggest you replace the LCD screen, pearlboslem. It is damaged.
If you post the Acer Aspire model number, I can find replacement LCD screens for your perusal, and should be able to find a Service Manual. (Free)
I will also guide you step by step the best I can.
This is on the Bottom of the laptop in a white Service Tag.
If you have never replaced an LCD screen in a laptop, the task may look daunting.
I assure you it isn't.
Generally the plastic strip that is above the Keyboard, and below the LCD screen, is removed.
Usually the Power On button, and LED indicator lights are in this plastic strip.
Different manufacturers have different names for this strip of plastic.
LED Cover, Power Button Cover, etc.
With a lot of Acer laptops the LCD screen can simply be accessed by removing the Display Bezel, and the plastic strip does not have to be removed.
(Some laptops do not have a plastic strip)
In the front of the LCD screen, and surrounding the LCD screen, is a thin plastic frame.
This is the Display Bezel.
Most display bezel's have rubber screw covers, going around the front of the bezel.
These are gently picked off with a computer pick, or suitable tool.
They have a type of rubber cement on them, and if careful, they can be reused.
(Stuck back into place)
The screws are just Philips head screws. Once removed the Bezel is slightly flexed, and popped off.
{The outside edges of the Bezel have tabs. Plastic protrusions formed out of the Bezel itself.
These tabs mate up with mating tabs in the Display Cover. The top cover of the laptop.
The tips of the fingers are put on an inside/middle edge of the Bezel, and used to gently ease this inside edge up a little. (Care is used so that fingernails do not touch/scratch the LCD screen)
With the inside/middle edge brought up enough to insert a second finger, the second finger slides down, and eases up on the inside edge again.
The tabs will start popping loose. The procedure is to keep moving along the inside edge with your finger tips, and keep popping the tabs loose. Once you are 1/2 way around, or so, the Bezel will pop free.
Some bezels do not have screws. The Bezel is flexed as above, so it is distorted, and the tabs pop free }
Once the Bezel is removed you are looking at the LCD screen, and how it is fastened to the Display Cover.
The LCD screen is an assembly. It is composed of layers. The layers are held in place by a screen frame. A thin metal frame that resembles a picture frame.
Usually on the left, and right side of the screen frame are metal brackets.
These are attached to the screen frame with two to four screws.
The screws are removed, and the LCD screen assembly is almost ready for removal.
There are cables (Wires) that have to be removed from the LCD screen, the Inverter at the bottom of the LCD screen, and maybe wireless antenna wires.
This gives you an idea on replacing an Acer LCD screen. Different models are shown.
Along with a pictorial guide, I may be able to find a Service Manual also,
http://www.insidemylaptop.com/category/1-acer-laptops/
At the end of every article for each laptop model, you will see in red -
Read the rest of the entry
Click on this for the full article on that model of laptop.
You can click on each photo shown to enlarge it.
Just to show you how relatively easy it is to replace an LCD screen, in an Acer laptop.
Post the Model Number, and I'll give you more exacting information.
Regards,
joecoolvette
Oct 10, 2011 | Computers & Internet
When i opened my lexmark 1200 printer to replace the ink cartridges, i noticed a long thin strip of plastic was loose. and now the cartridges dont move back and forth smoothly but clunk to either side and...
If the encoder strip has become unseated: 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover. 3 Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer. 4 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back. 5 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 6 Reconnect the power supply and turn the printer back on
If you need some graphical reference, please refer to this article: Printer Cartridge Stalls or Is Blocked .
Apr 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
I can't print my documents. My Printers model is Canon IP2700 and it says there that the error code is 5100. How can I fix the problem? we need the print immediately. Is there any solution we can fix it?
Usually, error code 5100 means some kind of obstruction in the print path, maybe something that had fallen inside the printer, the gears being jammed by something that got loose inside the printer, or ink on the clear plastic encoder/timing strip (a plastic strip about 1/4" in width that you can see running from side to side and connects to the print head).
Clean the plastic strip with alcohol , check if there is nothing blocking the head carriage set (sometimes kids play and hide toys, pens, coins, inside printers, VCRs or any other devices that have "doors"...).
Hope this info may help you!
Mar 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
The VCR eats tapes. Opened it up and see a thin white plastic strip loose on one end. The loose ens has a **** in it and I'm guessing it's supposed to be attached to something.
A dirty VCR will do this and usually has little to do with loose parts.
If you are not comfortable doing the cleaning take it to a qualified repair shop.
In this day and age it is most definately cheaper to replace the unit.
Good luck
Sep 18, 2009 | Zenith XBV713
None of the gauges work?
Suggest that it is a bad ground.
Your instrument dash is made of plastic. There is a large plastic strip on the backside of it, that contains Thin, Very, small copper strips. These copper strips conduct electricity to the gauges, and also a ground source.
There is a flat cable, or wire, (Or more than one), that connects from that plastic strip, to the metal body of your Jeep. This is the ground source to that plastic strip. If it has a loose connection, (loose bolt), corrosion, or rust at the connection to the body, or is broken, you will have lost your instrument panel's ground.
Also there should be 2 flat braided cables leading from the firewall, (Hood open. Under the windshield), to the engine. These need to be connected, and there should be 2 of them, not 1.
Aug 02, 2009 | 1989 Jeep Wrangler
Plastic strip fallen off from the ink slide
You are referring to the encoder strip. They can be reinstalled. They must be threaded through a sensor on the back of the carriage.
The mount at the left side has probably been pulled out of position. If the mount is not sitting properly the strip will be loose and will cause problems. The tension mount has two flanges that must be behind the plate it is mounted on. Good luck.
Jun 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Carrier Jam
This is what my printer did when it kicked of the 14" plastic strip inside the printer(see posts referring to strip). Look inside for a loose, quarter inch wide and 14" long plastic strip with slots on the end. Let me know if you solve this.
Dec 15, 2008 | Dell 926 All-In-One InkJet Printer
ML1710P
you may need to 'select' the printer in your control panel. Or the printer driver may be blown.
Feb 06, 2008 | Samsung ML 1710 Laser Printer
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
142 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
