Question about Altec Lansing MX5021 Computer Speakers
Computer won't read audio unit.
The speakers worked fine until I rebooted by computer back to its factory settings. Now the speakers dont play anything, and when I checked in my control panel, it said there was no audio device... I have tried re-plugging in the wires, however that has not fixed my problem.
  • 1 more comment
  • alexriggs10 Feb 05, 2008
    I do not know if I have the motherboard CD, or for that matter what the motherboard CD would look like. If it simply requires intalling a driver, could I not just find a driver online?
  • Anonymous Nov 29, 2008
    ya, i have the same problem "The speakers worked fine until I rebooted by computer back to its factory settings. Now the speakers dont play anything, and when I checked in my control panel, it said there was no audio device... I have tried re-plugging in the wires, however that has not fixed my problem."
    And i don't have any CD that came with it at the time of purchase.
    kindly give me a solution.
  • Anonymous Dec 08, 2008
    My Altec Lansing computer speakers worked fine untill i rebooted my computer. I scanned my computer and nothing showed up so i looked for the disk to re-download the system but couldn't find one!
    Plz Help me!
  • 749 Answers
Still there is no problem to your speakers... it's the Sound Driver is missing for Windows to activate the audio part of the motherboard... If you have the motherboard CD.... System properties and install the driver in order to restore that missing file...
Good luck.. Hoping this Fixya the problem... post me back if you have other inquiry... Just don't forget to rate us...
Posted on Feb 05, 2008
My sound won' t work on motherboard could it be that my onboard audio Is burned out... Kind Regards
i dont think it has burnt out
if your computer came with a motherboard disc the sound drivers could be on it:
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 07, 2011 | Computers & Internet
My speakers won't play any sounds when hooked up to the computer. I hooked it up to my ipod and it played
im not sure i understand what won't means????????
if you are having problems with your sound
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 18, 2011 | MidiLand MLi 691PA Computer Speakers
I recently needed to reboot my computer back to factory setting due to what I figure was a virus now my speakers won't work. I have speakers labeled Logitech X-530 do I need a disk to add this as new...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 07, 2010 | Logitech X-530 Computer Speakers
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
Packard Bell speakers screeching sound
Are they plugged in to correct sound socket on back of computer
even if they are on monitor
Jul 05, 2008 | Packard Bell Speaker Computer Speakers
DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Mar 15, 2008 | Televison & Video
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
No sound
make sure that the speaker cables colored plug match that of what is on the back of the computer, also make sure that the volume control console is set for the correct output. Lastly, if none of these work, try uninstalling the audio device by right clicking my computer, select properties, go to hardware, and click device manager and thenright click the audio device and click uninstall, then reboot, and follow the instructions that come up when the computer reboots, and see if that works.
Mar 03, 2008 | Sony VAIO VGC-RB50 PC Desktop
I only hear sound out of two speakers........
Have you set the computer up for 4.1 speakers in the audio software? Go to start control panel and click on sound's speech and audio device's, then click on sound's and audio device's. A window should pop up with a load of menus at the top, click on the one that says volume. Where it says speaker settings click on the advanced button. Click on the menus until the picture lookslike your system you have.
Feb 19, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
Altec Lansing MX5021 Computer Speakers Logo
181 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
