Question about Cobra 25 LTD 40-Channels Base CB Radio
Just a thought from Mechanic
Have him also try a Pa test with the spkr plugged in the pa slot to see if the mod section is working or not. Is the radio TX modulating? if so, wouldn't the chip still be good? One other thought, maybe the legs of the spkr jack is pulled loose from the circuit board. Good luck with it,, Mechanic
    Genius:
  • 1,274 Answers
Well, first your pa does not go thru your audio chip,take the cover off,with the radio circuit board down, the audio chip is on the right side-rail,the chip close to you, now turn it over and inspect it for cold solder joints,if you need to replace it you have to heat sink it with heat sink silicone, to remove it you need wire wick,it soaks up the solder,make sure you clean the old off with a paper towel,use 60-40 rosin core solder........hope this helps.....
Posted on Mar 12, 2010
6ya staff
SOURCE:
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
CB in Receive Mode Plays Out the PA Speaker
no,its supposed to work that way so you can monitor it while you are outside your vehicle.
Are you following the user manual that came with the radio?
NB-ANL/CB/PA SWITCH: When the switch is in the NB/ANL position, the Noise Blanker (NB) and Automatic Noise Limiter (ANL) circuits are activated.
The Noise Blanker is very effective in eliminating repetitive impulse noise such as ignition interference. In the CB position, the PA function is disabled and the radio will transmit and receive on the speaker that is connected. In the PA position,
the radio acts as public address amplifier. Your voice will come out of the speaker that is plugged into the PA. SP. jack on the rear panel. The radio does not operate when you are in the PA mode.
When you plug a speaker into the ext. jack does it kill the radios internal speaker? It should until you unplug it; if not and you are following the about you may have a wiring issue with the jacks.
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
Cobra 29LTD speaker inop....No audio at all. Speaker Ohms out ok as do speaker leads from board to speaker. External speaker jack is inop. PA works in PA and CB modes. Other than speaker issues, radio...
There are some different things you could be facing like:
the speaker sound being cut-out by the mic switch, but my first guess is the switch in the external spkr. jack being faulty. Here is a schematic for you.
http://xbones_antennas.tripod.com/id21.html
Apr 12, 2010 | Cobra 29 LTD CB Radio
Cobra 142 gtl no audio on receive work on pa, an on ext spkr get talk back,,,,but there no talk back in radio.... no audio on int spkr. tx good...
Hi and welcome to FixYa,
Initially, the speaker of course has been checked?
Offhand, would partial schematic of the mic and speaker section help?
Good luck and thank you for asking FixYa.
Dec 18, 2009 | Cobra Radio Communications
CB radio PA speaker
Freddy, hello. The first thought that comes to mind with your problem is that if the 29 is an older model, the audio circuit or audio chip could be tired. If your talking about the receive volume being low thru the ext. speaker, then there is a rx. wire inside the mic cord. When it breaks, it cuts the volume in about half. The rx. wire is on pin # 4. Maybe your using the wrong ohm value speaker. You need 4 or 8 ohm. If you are refering to the outgoing modulation being real low, then the radio mod. has just been turned down to 50-60%. That's about all I've got for now, not being able to actuallly see the radio,,, Have a good day, and let me know how it goes,, Mechanic
Oct 22, 2008 | Radio Communications
PA speaker quiet
I think this is a double post,, am I right Freddy??? Mechanic
Oct 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
I have a Cisco 7206 and it does not recognize a pa-8e port adapter
Hi Ckrebs,
Can you check what is the ios version of the 7206 (the one not able to recognize the PA-8E)?
Minimum versions of IOS required for pa-8e are the following:
Cisco IOS Release 12.2(4)B or a later release of Cisco IOS Release 12.2B
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/ethernet/pa-8e_10baset_install_config/3494prep.html#wp1024649
Check the ios of the router if it supports the PA since you were able to isolate that it's not a faulty PA-8E (by testing it to another 7206 chassis).
Once checked, can you provide the show version and show diag output?
Regards,
ex_ocsic_cat
Oct 20, 2008 | Cisco (PA-8E=) Expansion Module
The front led flash 10 times and the tv no turn on
Change the P.A board resolve problem. try to buy in www.shopjimmy.com.. if the front led flash 10 times is a tunner voltage problem.change this board. The P.A board Number is TNPA3620
May 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Cobra 25 LTD 40-Channels Base CB Radio Logo
100 people viewed this question
Top Cobra Radio Communications Experts
Chris
Ernest Taylor
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
