Question about Samsung ML-2510 Laser Printer
ML-2510 I have some pre-printed invitations, about 5,000. I am only printing the date and address on them. Easy job. The first 3,000 went without a hitch. I changed cartridges and now the machine jams every few sheets. Sometimes it will print 20 in a row and sometimes it will only print 2 and then it jams again. Help!
    Champion:
  • 204 Answers
Sound like the printer cartridge is either bad ..or now snapped in properly..might try to clean the feed roller the one that pick the paper with a cotton swab or lint free rag with some isopropic alcohol. paper dust will cause slippaged and jam. should be located either in the paper tray or just look above for black or grey rollers (when you have the tray out)
Posted on Feb 05, 2008
My samsung ml 2510 wont print. seems to start up ok, although it had been taking a little longer to warm up recently
hello problem is your toner cartridge change the toner cartridge and try to print.then warming up is became ok.
Jan 13, 2011 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
Can't print envelopes
is this the first time you use word ?
if it is any of the newer version 2003, 2007. the printing of envelope is as follow:
open the word, elect tools>>envelopes and labels. type in the delivery address and return address. click add to document.
completed you letter.
whenyou want ot pin the envelope, hig light the delivery address on the document, file, pirnt, type in 0 (zero) in the pages box under the page range (in the middle of the popup, under the "curent page button).
Mar 26, 2009 | Samsung ML-2510 Laser Printer
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 doesn't respond....
I solved this problem with windows xp but have yet to solve it with windows 7. what worked for me is hooking up the hp print server to my network switch and to the 2510. Then I installed the 2510 driver using the samsung exe and choosing NO when it asked about installing the driver without the the printer attached. The NO choice continues and installs the driver. Then run the HP printer wizard choose drivers on this computer when you get to that spot. Then choose the 2510 driver and finish up. You may now have 2 2510 installations and may need to delete the default one under printers and set the other as default. This worked on 3 different xp machines for me
Sep 24, 2008 | HP JetDirect EX Plus Print Server
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
I had the same problem and found the solution on the Apple discussion boards. Apparently, OSX 10.4 installs the printer as a Lexmark 510 series, not a Samsung ML-2510.
Just add a new printer and change the type from Lexmark 510 series to ML-2510 series.
Worked a charm for me!
See: http://discussions.apple.com/thread.jspa?messageID=5955598
Aug 12, 2007 | Samsung ML 2010 Laser Printer
Samsung ML-2510 Laser Printer Logo
148 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
