Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Fridgidaire CGLEF379DCC Gallery oven/stove - electric
Two problems - Self cleaning mode does not program/operate. It just deselects itself a few seconds after I set it.
2nd problem - I need to buy two new oven door hinges. I am in Toronto. Where would I start to look for these?
Gavin
  • 298 Answers
SOURCE: self cleaning oven
This is the link
http://safemanuals.com/user_guide_instructions_owner_manual_ELECTROLUX_316257104EN.htm#
Posted on Nov 21, 2007
SOURCE: Fridgidaire Gallery Model#CFES387CFS6
tech17 posted the reply in december that worked for my oven w/same problem. hold in door button and pust cancel and it will reset after about 5 - 10 secs
Posted on Jan 19, 2008
  • 150 Answers
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Posted on Apr 22, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
SOURCE: self cleaning oven instructions
My oven is beeping and display F 1 what does this mean
Posted on Feb 18, 2009
My Fridgidaire Gallery dryer is excessively heating up when we use it. I have cleaned all the vents, so I assume it is a bad thermostat.
my maytag electric stove oven door is locked, i tried pressing cancel, unplugging the stove from wall and it still will not open!! I was not in cleaning mood, it just locked on its own!! help, i cant use the oven!!
Jan 07, 2011 | Frigidaire Kitchen Ranges
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Fridgidaire FGF 374 CCSA oven and broiler do not come on
F1 means it is a defective eeprom. The software is incorrect. Replace EOC. Check inside the bottom drawer on the right side: there was an envelope with the troubleshooting and maintenance diagrams in it.
Jan 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigdaire gallery stove
Dec 18, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
138 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
