Question about Toshiba 20HLV15 TV
Toshiba 20hlv15 image turns bright colors and will sometimes disappear.
Hi i have a Toshiba 20hlv15 when i turn set on sometimes its fine but after being on for a while the screen colors start to act weird turning bright shades of green or other colors and sometimes the image disappears completely turning lcd off and on sometimes solves this problem and image will return to normal. can anybody tell me why image colors become distorted and how to fix problem?
  • Andy12345678 Mar 28, 2008
    I have the same TV with the same problem. I bought mine at Costco in 2005 (before they changed their return policy on TVs). I don't have the original box or receipt, but I called Costco and they said that they will allow me to return the TV for a full refund.
    Problem Solver:
  • 7 Answers
I took the unit completely apart and reassembled it, making sure to check all harnesses. I have been running the TV since I put it back together and it has been fine so far (3 hrs.). I was hoping that it was just a loose harnessToshiba 20hlv15 image turns bright colors and will - 4.gif when taking the unit apart. Although, I did not note a loose harness. The dvd player went wacky by just having the harness slightly off. I will run the unit some more and post my findings. I have to say I'm surprised that this is not a more common problem considering there are numerous people with this particular unit with the same issue. Also, just a note the unit was very clean inside, no dust issues, no blocked cooling ducts.
Posted on Mar 30, 2008
  • Michael Borquez Apr 02, 2008
    Still running great...
  • Michael Borquez Apr 04, 2008
    I have to say that this was an effective fix to just take the unit apart and remove all harnesses. One of two things happened.
    1. There was a harness that came slightly loose.
    2. There was a static charge in one of the boards that was released by unhooking all of the harnesses.
    This unit is quite complicated and should not be taken on by a novice. But, with that said I would like to let others know that this is not an expensive fix.
    Scholar:
  • 103 Answers
Sounds like a bad connection in the set and the heat from being on causes the connection (wherever it may be) to open, causing that colors circuitry to stop working. This is most likely something that can only be fixed by someone who can actually get their hands on the thing. Sorry, but I don't think anyone online can help with this problem.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
Trutech Digital Photo Frame
Image quality using default factory settings is awful. Colors are over-blown, faces are washed-out, and highlights are cropped. People on the internet compained that there is no brightness control -- there is..but its hidden in a menu. Press the Setup button on the remote and move to the "System" settings. I've found these settings produce a fairly correct balance of color, detail, and brightness:
* Brightness=5
* Contrast=1
* Saturation=2
Mar 31, 2008 | Electronics - Others
I will check what toshiba says about this problem, but in the meantime, make sure your tv is not overheating, make sure all airvents are open, you said you took it apart so I supose you cleaned all the dust and so on.
Il get back to you.
Mar 30, 2008 | Toshiba 20HLV15 TV
Need replacement stand for 20HLV15
If its a Toshiba as indicated here call their customer service and get a part number for the base and a price and availability.
Apr 30, 2012 | Toshiba 20HLV15 TV
Toshiba L300 screen flickers and backlight
Maybe is the backlight power cable cut. Try with the laptop in power on mode oppening VERY SLOWLY the screen to see if at a certain potition it works fine. Open it all the way up sometimes to check it. If thre is a potition that it works, it's the cable as I mentioned.
Stelios
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Jan 12, 2008 | Vizio L37 Television
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Color "burn" in corner
well i think this is caused by a magnetic field created by your speaker. is the speaker the same location for that color burn (lower left corner)? the only way to get rid of that is to remove your speaker or changed it. for all i know speakers used in tv's are magnetically shielded to prevent distortion in the CRT, because their location is usually near the crt. good luck!
Jan 30, 2007 | Toshiba 27AF45 27" TV
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 20HLV15 TV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
