Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAVT834AWW
My washer's spin cycle wasn't working and we replaced the belt. That only fixed the spin cycle. Now that's the only thing that works. I turned it on and put it to a normal setting and all I hear is a soft buzzing. It won't fill or do anything else. Any thoughts?
    Sniper:
  • 65 Answers
Did you turn th e water back on?
Posted on Feb 18, 2008
2 Suggested Answers
aquatom
  • 108 Answers
SOURCE: Maytag atlantis mavt834aww stopped in mid cycle
Try unplugging it wait a minute and replug it in. This will sometimes reset the main board.
Posted on Sep 25, 2011
Maytag atlantis mavt834aww stopped in mid cycle and now won't do anything.
Sep 25, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis will not agitate it runs through all the cycles it will spin but will not agitate. The belt is intact.
WELL THATS BECAUSE ITS AGITATED WITH THE XTRA LOAD YOU PUT IT THROUGH WHEN YOU ARE SITTING ON IT NOW I KNOW ITS FUN BUT SPIN CYCLE IS ONLY DESIGNED FOR WASHING CLOTHS...I HOPE THIS ADVISE FIXED YOUR PROBLEM.
Oct 31, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Aug 31, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Wash cycle dose not work
There is a small white micro switch mounted near the lid switch. This is a called a check switch. Replace it.d023fa4.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Dec 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader won't do the wash cycle
hate to be bearer of bad news, but the transmission is the culprit this time.
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Mav6260 washer will not spin
the belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
469 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
