Bad gas smell. Not good. Does operate fine after a minute or two.
SOURCE: Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes
Other reasons that your oven may not bake are:
if this helps please vote me a fix ya
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
SOURCE: matag gas oven won't or is slow in comming up to temperature.
Hello and welcome to FixYA!
You are 100% correct in your suspicion that the oven ignitor is at fault. If you want to know "for certain" you can check that ignitor in circuit using an amprobe and looking for at least 2.9 amps, however I would say all you need do is replace that ignitor and your oven should return to proper operation. The gas smell is a result of an ignitor being on the "ragged edge" of being able to open the warp switch in the gas valve. Instead of opening up, it is "burping" the valve enough for you to smell gas. Your part number is a
12400035 and sells for around $50 or so, depending where you buy it.
Thanks for using the FixYA! service!
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
