Question about JVC AV-35750 35" TV
WON'T TURN ON. POWER SUPPLY GOOD
JVC AV-35750
  • walker4run Feb 05, 2008
Replace capacitor C926 near center of circuit board chassis (label is on bottom) by a 1000uF 50V one. Mind the polarity!
R,
A
Posted on Feb 05, 2008
3 Suggested Answers
SOURCE: POWER WON'T TURN ON . YES, POWER SUPPLY OUTLET IS GOOD
Replace capacitor C926 near center of circuit board chassis (label is on the bottom) by a 1000uF 50V. Mind the polarity!
R,
A
SOURCE: JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Posted on Dec 07, 2008
Jvc tv won't turn on
Check its main power regulator section for damaged component/s
Nov 30, 2012 | JVC AV-35750 35" TV
What's your problem?good I have this problem it is that my TV started with a noise when you turn it on and at the time became strong after is normal
you have to remove the cover then look at the main board, turn the power on then observe if the cause is coming from the Flyback transformer or a leak capacitor.
Oct 15, 2012 | JVC AV-35750 35" TV
JVC AV 35750 wont turn on
The main board should be trouble shooted. It wounds that the chroma section circuit has the fault. Might be chroma IC.
May 29, 2012 | JVC Televison & Video
JVC av-35750 digital or analog???
Unfortunately this TV does not have a digital tuner built in.
Is not digital ready.
Jun 28, 2009 | JVC AV-35750 35" TV
TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 15, 2009 | JVC AV-35750 35" TV
JVC AV 35750
its a boat anchor dont break jus hvy
Aug 06, 2008 | JVC AV-35750 35" TV
JVC AV-35750 TV
Jul 28, 2008 | JVC AV-35750 35" TV
Power supply problem
My tv did the same thing. Replace the capacitor marked C926 that is marked on the main(big) board. It fixed mine. The lead was broke off inside the capacitor.
Jul 12, 2008 | JVC AV-35750 35" TV
R,
A
Feb 05, 2008 | JVC AV-35750 35" TV
Televison & Video Logo
226 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
