Question about Kodak EasyShare C875 Digital Camera
Won't work Have a C875 for a year now, and it has been working just fine. The other day I decided to try a AC adapter on it. Well, the AC adapter I used is one of those variable voltage ones. I set the voltage for 3 volts, plugged it in, it doesn't work. O.K. I put the batteries back in, still don't work. And, to top it off, the batteries get hot. Took the camera apart and I don't see anything burned up. Lost. Any help on what the solution could be and how to fix it would be greatly appreciated.
  • 98 Answers
Oh no maybe you used different adaptor some adaptor have reverse polarity. check the adaptor before plugging it..if you using variable voltage set to 3v then adjust also the polarity. the polarity should match the polarity of your camera.
Posted on Feb 05, 2008
Laptop Won't satrt if AC adapter plugged in. Works fine on battery
Hi, Try to Upgrade BIOS.
This will work same problem i had with my HP Notebook....
My laptop was also working good without AC adapter and no response on Charging connection.
Apr 26, 2013 | Toshiba Equium A200-1vo 15.4" 1.4 Ghz...
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
My acer aspire 4330 won't power on?
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 26, 2011 | Acer Aspire 4730-4947 Notebook
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
My laptop won't charge. I only had it for two months.. I think it is the battery not the charger... Will the warrenty cover that?
Aug 17, 2011 | Sylvania G-Netbook
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My Dell Inspiron Mini won't power up. When I push the "on" button, the light indicator flashes and goes off immediately.
Jul 21, 2011 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
98 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
