Question about Sub-Zero 632 / S
Sub zero constant running, vacuum condenser
Ok so I have read and all I have found out is my fridge sucks.  I have 632 and I have vacuumed condenser and air compressed it out and wiped the inside spotless the fan the arms the entire compartment is clean. now it runs for hours on end. So the trick, if I turn it off and turn it on it stays off for a hour or so then it comes back on and runs for hours again. If it runs all day while I am at work it will say vacuum condenser, in which I will turn it off and on again. So does this mean I need a new condenser every 3 years because it is a piece of junk? Is there a switch that is not working that tells the compressor that the fridge is hot and it is really cold. I don't thinks so because the fridge stays at 34 and the freezer at 5 unless I leave it off for a hour then it might go up to 37.
  • 2 more comments
  • Paul Sarlis
    Paul Sarlis Apr 26, 2008
    I have a sub 650 and it's doing the same thing after I vacuumed and cleaned the coil.  Is the thermostat an easy part to change out if this is the problem?
  • galwaykate May 09, 2008
    Had the exact same problem. In 2006 had the evaporator/dryer unit replaced. No vacuum condensor light until last week. Now have the same issue, having it serviced on Wednesday. This is frustrating!!! However, customer service at subzero has been excellent!!!
  • cladrian Jun 21, 2008
    I have a 632 that has been generating heat on the door jamb. The freezer and fridge cool fine, houever items near the door like icecream will not cool all the way. What gives??
  • laurietokars Sep 07, 2008
    I have a sub zero sise by side that the door jambs just started getting warm also. The fridge is 4 years old. Vacumned condensor and area also. Seems to have helped but what could be going and what should we try to replace first
Probably a  thermistor. common part to go bad in these units
Posted on Feb 06, 2008
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Feb 21, 2015 | Sub-Zero 690 Side by Side Refrigerator
Vacuum condenser flashes on and off, freezer side has warmed up But the freezer fan is still running to circulate the air.
It is telling you that you need to vacuum the condenser coil. if this fails to cure the warming problem then you my need a new condenser. compressors have also been know to cause this.
Dec 20, 2010 | Sub-Zero 632 / S
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
Refrigerator side of side-by-side model 632 not cooling below 50 degrees and message display reads "vacuum condenser" but I have been vacuuming the condenser to no effect.
I'm sorry we must have got disconnected somehow, like I said the problem is going to be with the defrost system or the evaporator motor from the limited information you gave me...hope your problem was resolved. Thanks! Mike
Jul 15, 2009 | Sub-Zero Refrigerators
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
I have a ten year old Sub-Zero 650. The "vacuum condenser" has been displayed for over a year even though the coils have been vacuumed and are kept clean. The fridge has been working fine despite the...
Look on your sub zero for more model numbers. I have found some information indicating that the refrigerator thermostat may be the problem but need those numbers to confirm. Thanks, Sea Breeze
You can also find a user manual at this link
http://safemanuals.com/zearchres_663.php
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Mar 07, 2009 | Sub-Zero 632 / S
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero 632 / S Logo
613 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
