Question about Acer AOpen AK77 Pro(A) (91.89A10.104) Motherboard
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
    President:
  • 2,351 Answers
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Posted on Jan 07, 2010
SOURCE:
How do I restore XP rundll32.exe?
I've used SFC to repair Windows 2000/2003 servers in the past, it debuted in Windows 2000 and it fixes system dlls. Start > Run > type 'cmd' and 'sfc /scannow'. You will have to insert a Windows XP SP2 cd for it to work (or mount and ISO of XP with a tool like alcohol 120).
If the %systemroot%\system32\dllcache folder becomes corrupt or unusable, use sfc /scannow, sfc /scanonce, or sfc /scanboot to repair the contents of the Dllcache directory.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/system_file_checker.mspx?mfr=true
Jan 12, 2012 | Toshiba Satellite P105-S9337 Notebook
Mother board is ak77 pro 133 vt8233 will not run xp proI
The BSOD (blue screen of death) usually means that a computer component has failed. This could be a hard disc drive, a memory module, the cpu, or the motherboard. I would start by checking out the hard drive first. See if it is spinning and not making any clicking sounds. Try replacing it if you have another one. Then check memory and cpu. Some people actually like having an old computer hanging around. They install Windows 98 in it so they can play old dos games and games that don't require a blazing fast processor! Good luck...Hank
Jan 09, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Does the FSB 800 mother board only support Vista drivers? I would like to run windows 2000 or XP but I was told only Vista drivers were available.
This board is WinXP designed and certified.
http://www.msicomputer.com/index.php?func=proddesc&maincat_no=1&prod_no=569
Dec 15, 2009 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Version mother board?
This should be the drivers for 90% of the P4M Boards .
http://drivers.softpedia.com/get/MOTHERBOARD/Others/Via-VT8231-VT8233-VT8235-VT8237-Motherboard-36.shtml
Oct 16, 2008 | EliteGroup P4VMM2 Motherboard
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
MoBo Replacement
did you go into the new bios and check to make sure you have the hard drive setting on auto, then check your boot order that the drive is first to boot., if that doesnt work create a floppy boot disk (google it) and see if you see the hard drive when you do that.
Feb 15, 2008 | Computers & Internet
Disabled onboard video in bios in hopes that new video card would kick in, now how do i turn it back on so i can see again
with a second monitor and win xp, you can run both videos. just plug in card and plug in second monitor and xp will take care of the rest...you will see special messages first boot
May 28, 2007 | AOpen MX4LS (91.88Q10.001) Motherboard
Open Questions:
See all Acer AOpen AK77 Pro(A) (91.89A10.104) Motherboard Questions
Acer AOpen AK77 Pro(A) (91.89A10.104) Motherboard Logo
146 people viewed this question
Ekse
Alun Cox
