Question about Mitsubishi VS-45607 45" Rear Projection Television
1995 mitsubishi 60inch big screen
I really need help with my big screen tv because some times the picture turns off it turnes off while i watch it an to get the picture back i hit the tv and it comes back but only for a little while
  • akaosk1 Aug 21, 2008
    Our tv goes off after heating up then when we turn it on again once it is cooled down we can watch it again
  • Mitsubishi Master
  • 8,617 Answers
Probably a solder issue. try soldering around the flyback, line coilsand vertical and yoke plugs. You can get a service manual for 10.99 emailed to you at the following link. they also offer free support to help with the diagnosis of your Set.
http://servicemanuals.vstore.ca/
Posted on Feb 05, 2008
I have a 60inch 1080p big screen Mitsubishi tv with atleast a 1000 little white spots and tv turns off frequently when 1st turned on what is wrong?
The white spots sound like the Optical Light engine has a bad display, they sometimes start with one or two and multiply.
The engine is about the most expensive part in the set, see attached photo of one
Dec 21, 2012 | Televison & Video
The screen has a blue like tint around the edges of the screen..what can i do? it's a magnavox 6p6030w101 60inch projection tv.
you have coolant in your red, green, and blue picture tubes. this coolant will start to turn dirty as time goes. the coolant should be clear but when it starts to turn, your picture has like a haze in it. coolant needs replacing. suggest local service center
Nov 08, 2009 | Televison & Video
I have a 1999 big screen purgation mitsubishi tv and when i turn it on it go's to this ant-B and under that it would say stereo SQV and i can hear the show that is playing from the cable box but it dont...
If you go into the Main Menu for the TV with the Remote, then into set up, look for a adjustment that says Monitor or TV.
It sounds like it is in Monitor mode.
Hope this helps,
Skyassoc
Jun 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Help with my big screen mitsubishi ws65869 tv
my screen is a right blue with no picture although I have sound it reads "tuner out"
Mar 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Big screen tv picture problem
You most likely have a problem with the Diversity circuit. This is an upright module on the mainboard.Just clock the invertersignal using your watch (it should change every second). If that is the case, you might need to set up the ghost-setting.look in the menu for the ghost-parameter (set to '28' by default)and change it either up or down. if its not responding then you might have a problem with the CMP-board and that is a little costly.
Sep 03, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
