Question about RCA TruFlat 27F520T 27" TV
T v channel
My tv say tv3 mono
  • Paul Teichmann May 11, 2010
    So what exacly is the problem? What are you not able to do?
    New Friend:
    Problem Solver:
  • 15 Answers
Tuners are a big source of problems on this model, i may suggest using your cable or sat box as the tuner by going from the video out of the cable or sat box to the video input on the tv, select video on tv and let the cable boxt v channel - 1.gif or the sat box act as the tuner, if you are using outside ant then use a vcr as your tuner to the set. this is a easy and cheep way to fix your problem.
hope this helps ya.
Posted on Feb 08, 2008
2 Suggested Answers
MARR
  • 49 Answers
SOURCE: channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
Posted on Feb 05, 2008
How to tune samsung tv
Mono is the first point I am stuck on. Mono is an audio reference but I am going to assume that you are only receiving the analog channels and not the digital. If you are coming off of an antenna then the antenna has to be HD to receive HD channels over the air. If you are off of a cable box then this has to be dealt with from your provider. You will also need an HD ready TV or if you do not you will need an HD converter box to make your tv work with the digital signal.
Apr 02, 2014 | Televison & Video
Picture problems on tv3
you have to turn off the PIP option in the settings either in the remote controller or in the menu settings using menu button at the tv to go in the set up.
Dec 28, 2012 | Televison & Video
What does a mono status mean on the tv screen?
It does not mean much---sound may still be stereo but channel change often does not allow it to show.
With it on a channel listen carefully and switch it if possible from mono to stereo to see if hear mono or not.
Jun 11, 2012 | GPX Televison & Video
When I use the headphones listening to TV, I get the background sound (eg music) clearly but the dialogue is very low and drowned out by the background music or ambient sounds
It's because the TV's audio is stereo and the dialogue is mono split between two channels. When dialogue hits your headphones the majority of the mono signal gets cancelled. Try a different set of headphones or watch true stereo channels... IE movie channels
Apr 18, 2011 | Bose QuietComfort 2 Acoustic Noise...
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Jun 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Cant get mono off tv screen ..
The TV set itself will probably have a button that is marked either "Video," "Input" "Source" or "TV/VCR" - I would need to have your exact television model # to be sure. Make sure the cable box is on. Press the Video/Input/Source/TV/VCR etc button and see if your cable picture reappears on one of the source channels. If your television is connected to the cable box with a standard coaxial cable, then Ch.3 or Ch. 4 would be the right choice. If you have a digital cable box, however, the cable is probably going to be on an auxillary channel. If you give me the exact model # of your TV, and the type of wires that run from your cable box to your TV, I can give you more precise instructions. Good luck!
-Tha Mp3 Doctor
Feb 11, 2009 | RCA M4204 MP3 Player
Channel
Feb 05, 2008 | RCA TruFlat 27F520T 27" TV
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
RCA TruFlat  27F520T 27" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
