Question about Creative Labs Zen MicroPhoto MP3 Player
Detection by comp.
An alert pops up that it is detected but when i open one of the zen programs to transfer music it says that no device is connected, but it is!! its driving me crazy.
any answers? much appreciated
Plug it in - restart the computer
Posted on Feb 06, 2008
I need to download music and there is no file for
Using XP, the player should be detected through the USB port of the computer as a removable disk [also called MSC device].
note:
Before disconnecting the player, always go through the icon "Safely remove hardware" in the right corner below of the computer screen, to keep the player free from data loss or data faillure.
First prepare the player before connection / check normal working of the player:
0. Player NOT connected to the computer
1. Switch the player ON using the >| button
2. Check the HOLD icon in the display: padlock should be OFF
3. When the padlock shows up, unlock the player: slide the HOLD switch to the left: padlock should not show in the display now.
4. Switch the player OFF, holding the >| for about 3 seconds.
When the player should not behave normal, perform a RESET.
0. Disconnect the player if connected to a computer.
1. Remove the battery from the player and leave it out for 10 seconds.
2. Replace the battery.
3. Power ON the player with the >| button and see if the player works normally.
4. Switch OFF the player, holding the >| button for 3 seconds.
How to check the detection of the MSC device on your computer:
0. Player Normal Functioning, NOT connected, NOT locked and switched OFF.
1. Explore 'My Computer': click start in the left corner below of the computer screen and select 'My Computer'.
2. Connect the MP300 to a USB port; detection may take some time.
3. Look on the computer screen if a new removable disk shows up in the explorer overview, coming up with a new drive letter.
4. Now you should be able to put music onto the player, showing up as a removable disk with the new drive letter: use 'copy and paste' or 'drag and drop' method for music transfers.
note:
When no new drive letter shows up, try another USB port.
Connect directly to the computer, not through a hub.
If you need more help, tell me at what point connecting or transferring fails in this thread.
There's also a software program called Coby Media Manager that can be used for detection or transfers. Coby Media Manager is based on MTP connection mode.
Need help for this ? Write your comment in this thread.
May 28, 2010 | Coby MP300 MP3 Player
I cant synchronize music to my 30gb Zen Xtra
you probably need the disk it came with and if you cant find it look for it on the internet and you might wanna try a program called WINAMP to transfer music to your ipod
Jul 24, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Non detection by the computer
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Mar 10, 2009 | Orite CS780 Digital Camera
Wont play songs says i need sync license from pc
It depends on what program you use. If you use Napster, just connect the device and when the pop-up menu opens, click "Sync my music with Napster." I'm not quite sure what you do if you use other music downloading programs.
Feb 17, 2009 | Creative Labs ZEN V Plus MP3 Player
I need help transfering my music form the computer the the zen
What do you want to transfer it to? If you're putting it into an p3 player, once you have the music set as the type of files that your device will play, you should be able to drag & drop the songs right to the player.
Jan 03, 2009 | Beond Creative Technology Zen Mozaic MP3...
Creative zen music will not play on memory card
I also use Napster. Unfortunately with the music being on the memory card and not on the device itself, Napster detects this and will not play music from the memory card.
There are two things you can do to resolve this, the first one won't cost you anything. Move non-Napster music files to the memory card, leaving only Napster music on the device itself. As a Napster-To-Go device, you'll be able to play and sync without issues. The second is to purchase the tracks from Napster that you want on the memory card. Once you do this, you can play them in any compatible media - not just the Zen device.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Instruction for zen mosaic by creative
I think alot of people are having the same problem I was. We got home, opened the box, plugged it in the computer, and nothing useful happened so then we installed the mini-cd. Well the thing is windows stops looking for a driver once it searches and finds nothing, and unfortunately those of us using XP do not automatically have the drivers. So...
SOLUTION
-If you have not already installed the mini-cd, do so, or download from Creative's site in the support section(if you do you might want to grab the latest firmware update)
-Once pack has been installed the drivers have been as well, BUT as I mentioned we now have to tell windows to look for them again.
-Reconnect your Mosaic
-Right click "My Computer"
-Chose "Properties"
-Click the "Hardware" tab
-Click "Device Manager"
-A window will pop up and you will see a long list with (hopefully only) one thing under the "Other Devices" sublist. It should be something along the lines of "Creative Zen Mosaic". Right click it
-Chose "Update Drivers"
-Follow prompts agreeing to search and auto install
-Once install is done, in a moment the screen on your Mosaic will say "Docked"
-Congratulations!
If you have downloaded the updated firmware this is the time to install:
-Ensure your Mosaic is in "Docked" mode
-Execute the firmware update
-Click "Upgrade"
-Wait (it takes a moment or two)
-Updater will say it is complete
-Mosaic will reboot
-Click "Close"
-Congratulations!
Hope that helps.
Dec 11, 2008 | Creative Labs Zen Touch MP3 Player
Problem transferring MP3s to Zen Vision 30GB
I have a Zen Vision M 30G, and this is what worked for me.(Widows XP home Edition. First you're going to want to transfer all your files back to your PC to back them up. I've found that even though you can't transfer from your PC to Zen, you can transfer from Zen to PC. Connect your player, and after your Pc recognizes it go to My Computer>click on your player, it should show up as "storage media.">then you right click on it, then select "reformat." A warning should pop notifing that you will lose all you data. Click yes, It should take less than a minute to complete. So essentially you have just wiped your Mp3 player's hard drive clean. Now transfer all your backed up files back to your player.
Aug 16, 2008 | Creative Labs ZEN Vision:M Digital Media...
Turn on problem and detect by PC
I had a similar problem yesterday with my Creative ZEN V 2GB. After charging it with the USB, it wouldn't turn back on. No lights or anything.
I read somewhere that if you hold down the power switch for a few seconds, and while holding down stick a pin or needle into the reset switch on the side, it will reset the player.
Amazingly, this did work for mine. It now powers on with no problems. Hope that helps.
Sep 13, 2007 | Creative Labs Zen Nano Plus MP3 Player
Creative Zen nano plus write file delayed
My creative zen nano plus 1GB bought 6 months back, when connected to the comp it hangs...then after long time it gives an error message that write file delayed in F:. I didn't even try to write any file...the right click also hangs the computer after long time
Aug 01, 2007 | Creative Labs Zen Nano Plus MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
