Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
PARTITIONING MY FREEAGENT PRO 500GB
I AM UNABLE TO PARTITION MY FREEAGENT USING THE DISC MANAGEMENT IN WINDOWS XP. CAN SOMEONE EXPLAIN HOW TO DO THIS??
  • 449 Answers
Why dont you just make use of win98 bootable disc or smart installer to partition the stuff?
Posted on Feb 05, 2008
6ya staff
SOURCE:
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Tip
How to Dual Boot Windows 7 with XP or Vista
If you're dying to try out Windows 7 but aren't ready to give up your installation of XP or Vista, let's take a look at how to dual boot Windows 7 with XP or Vista.
Assuming you've already downloaded a fresh copy of Windows 7, you'll need to burn it to a DVD in order to do a fresh installation. To handle this task, grab a copy of the most popular CD and DVD burning tool ImgBurn, burn the ISO to a DVD, and move right along to step 1.
Step 1: Partition Your Hard Drive Before you go installing Windows 7, the first thing you need to do is create a new partition on your hard drive to hold the new installation of Windows. Partitioning your hard drive will vary depending on whether you're running XP or Vista—namely because Vista has a partition tool baked in, XP does not.
Partition Your Hard Drive in XP To partition your hard drive in Windows XP, you'll need to download some sort of third-party partitioning software. There are a lot of options available, but I prefer to stick with the previously mentioned GParted live CD, a free, open source boot CD that can handle all kinds of partitioning duties.
To use it, just download the GParted Live CD, burn it to a CD, then reboot your computer (booting from the disc). You'll boot right into the partitioning tool. HowtoForge's previous guide to modifying partitions with GParted is a great place to start, but it's a fairly basic procedure:
  1. Resize your current OS drive to free up enough space for a Windows 7 partition (the minimum system requirements ask for 16GB).
  2. Create a new partition from the newly freed space.
  3. Apply your changes.
Partition Your Hard Drive in Vista The folks at Redmond were kind enough to include a disk partitioning tool in Vista if you know where to look. So go to Control Panel -> System and Maintainence (skip this one if you're in Classic view) -> Administrative Tools -> Computer Management. Once you launch the Computer Management tool, click on Disk Management under the Storage heading in the sidebar. It's partitioning time.
Luckily we've already gone down this road before in step-by-step detail, complete with pictures, so check out our previous guide to creating a new partition in Vista. In a nutshell, you'll need to shrink your current OS partition to free up at least 16GB of disk space (per the Windows 7 minimum system requirements), then create a "New Simple Volume" from the free space. Step 2: Install Windows 7 Now that you've done all the heavy lifting, it's time for the easy part: Installing Windows 7 on your new partition. So insert your Windows 7 disc and reboot your computer (you'll need to have enabled booting from your DVD drive in your system BIOS, but most PCs will have this enabled by default).
Once the DVD boots up it's a simple matter of following along with the fairly simple installation wizard. When you're choosing installation type, be sure to select Custom (advanced) and choose the partition you set up above. (Be careful here. Choosing the wrong partition could mean wiping your other Windows installation altogether, so make sure you pick the new partition you just created.) After you select the partition, go grab yourself a drink and let the installer do its work. Windows will run through some installation bits, restart a few times in the process. Eventually you'll be prompted to set up your account, enter your license key, and set up Windows. Keep your eyes open for fun new Windows 7 features, like your new homegroup (and the accompanying password). When it's finished, you're up and rolling with your new Windows 7 installation.
Congratulations! You should now have a new entry for Windows 7 on your boot screen when you first start up your computer. You've now got all the tools necessary to dual-boot Windows 7 and XP or Vista—or even to triple-boot Windows 7, Vista, and XP.
on Jul 07, 2010 | Computers & Internet
Need to load xp on gateway
Do you have a full installation disc or an Upgrade version of XP? The full install should give you an option for partitioning and formatting the new hard drive as part of the installation process. From Microsoft, read this page for details:
http://support.microsoft.com/kb/313348 . You may need some additional drivers if you have a SATA hard drive. More screen shots and details are here: http://www.theeldergeek.com/hard_drives_03.htm .
An alternative way of dealing with the problem may be to use a third-party Partition Manager software (Symantec's Partition Magic, Paragon's Partition Manager). Paragon's site is
http://www.partition-manager.com/ . This site has various levels of Partition Management software (with different features available in the more expensive versions). You'll need the bootable CD version of the software (recovery disc, .iso) to do the partitioning.
I hope this helps.
(I thought the upgrade version could also be done to a new hard disc including the partitioning; all you needed was a Win OS disc from an earlier version to prove qualifying ownership.)
Feb 20, 2010 | Gateway 700 X PC Desktop
How to partition an external hard drive on windows xp?
Go to Control Panel => Administrative Tools => Computer Management => Storage => Disk Management.
The drive should be shown on the list, just right click for options, you can partition, format, change driver letter, whatever you need to do.
good luck!
Feb 04, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Trying to format for MAC
I had a similar issue and was able to work around it by partitioning the drive. See this site for information: http://www.kenstone.net/fcp_homepage/partitioning_tiger.html
Overview: Open Disk Utility, Click on the Drive, Click Partition, Choose the number of partitions, and click Apply.
(It's written for video editors, but is applicable in your situation)
Let me know if this helps!
Apr 18, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Partitioning lacie hard disk 2.0 500 gb
Windows XP: Right-click on "My Computer" and select "Manage". From there, select "Disk Management" which lets you view the drives and do things to. More details here...
If you're on Mac OS: Here's how
Mar 20, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
I have a freeagent go 500gb portable hard drive. Can I partition?
YES YOU CAN YOU CAN INSTALL AND USE ACRONIS DRIVE PARTITION OR CONTACT SEAGATE TECH SUPPORT AND THEY WILL ASSIST YOU.RICHARDM69
Mar 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer cannot find external drive
This sounds like it might of formatted the hard drive aswel and now needs partitioning.
Go to control panel then system tools then computer management.
on the left click disc management and see if it shows in this.
if it dont then you need to take the hard drive out of the case, and plug it into the computer inside via the sata cable and partion it in the boot options.
hope this helps
please rate
Feb 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
179 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
