Question about Canon PowerShot A520 Digital Camera
Hey i got my sd memory stuck in my camera i tried using tweezers but they didn't work. So any suggestions?
  • 619 Answers
Hi , all sd memory are enjectible you just push then will pop up, push once it will not pop up poll out with tweezer try second time until the lock will release.
Posted on Feb 05, 2008
Memory card holder stuck in the memory card slot
I hope you did not force the cardholder too much.
Normally you should press a little on the memory card or cardholder for the micro SD card, but if that does not work perhaps this will?
If you have a tweezer depilate, (ask your girlfriend or your wife)
you could use that to pull out the card holder.
Jan 26, 2014 | Nikon Coolpix L14 Digital Camera
Jammed sd card in d40x
You just try the SD card pull out by tweezers. first push it once and then pull by a sharp tweezers,
Aug 29, 2012 | Nikon D40x Digital Camera
1 Answer problem is that everytime i turn on my camera it says card requires formating and when i press format it still says card can not be read! is there something wrong with my camera or my SD sandisk...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 28, 2011 | Cameras
I put my psp memory card into the sd slot and now it wont come out wht shall i do?
Try using tweezers or very small needle nose pliers to get your memory stick pro duo out of the SD slot.
Mar 14, 2011 | Computers & Internet
Memory card stuck inside Memory card slot.
Your only bet is a pair of tweezers, The SD slot is not "openable" When these fail the whole reader assembly is disconnected from the motherboard and replaced.
I would say try your local beauty supply store or a pharmacy for a longer thinner pair of tweezers.
Should that not work you have to decide which is the lesser of two evils paying for a tech to replace the component or just leaving the card in there and forego the use of the reader.
Another option is to use a heavy gauge sewing needle to try to push the micro sd card towards the front where yo can grab it with the tweezers.
MAKE SURE the battery is pulled out and the laptop does not have power.
Jan 07, 2010 | Computers & Internet
Brand new polaroid i1237. I got a brand new sd card to add memory and it is stuck. Won't go in or come out ...??
hey elvie,
same thing happened to me. if you can pry out the sd card with tweezers or a small screwdriver....then flip it over so that the copper terminals are facing up....NOT THE the manual says. copper terminals have to face up....or towards LCD can use a flashlight to see inside the empty slot....then you'll know they have to face up.
i will email polaroid so they fix their dumb manual.
Dec 04, 2009 | Cameras
Sd card stuck in slot
you will have to remove the palm rest and then unplug the sd device look in the back of it and should be a small hole take a paperclip and push through the hole
Jul 27, 2009 | Toshiba Satellite L305-S5933 Notebook
The camera will not let photographs save to the memory card.
Hey abiwhitley,
Without knowing the camera you are using and what type of memory card you are using I would suggest you format the memory card in the camera. If this is a SD card it could be set to locked, which could not allow images to be written to the memory card. To remove the lock there is a slider on the side of of the SD card which you should make sure is set to the unlocked position. I hope this helps!
Go Ahead. Use Us.
Jun 11, 2008 | Cameras
Nintendo Wii memory card
Hey fish_it,
According to information provided by the manufacturer, the Wii does support standard SD memory cards (like the ones you would use in a digital camera or cell phone) in addition to those sold by Nintendo itself. The Wii also should support miniSD and microSD memory cards as long as they are used with their respective adaptors.
Please keep in mind however, that Nintendo has also made a public disclaimer about the compatibility of SD cards with the Wii, and the Wii may only be able to recognize SD cards that are 2GB or less.
If you're still not sure, I would strongly suggest referring to Nintendo's website for more information. Nintendo appears to have a list of SD memory card models made by third-party manufacturers that are licensed to work with the Wii.
Hope this helps you out.
Go Ahead. Use Us.
Jun 05, 2008 | Nintendo Wii Console
Canon PowerShot A520 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
