Question about Refrigerators
LD refridgerator icemaker not making ice
The icemaker does not fill with water to make ice , the water dispenser works and pressing the button on the icemaker causes it to flip the tray and cyle but there is no water coming to the icemaker to make cubes.
  • minnie46 Mar 02, 2008
    got the water to come through the door but now the ice maker is not getting water to it?
    Scholar:
  • 64 Answers
I personally have never heard of your particular model ( LD ) - bearing in mind that most fridges with these types of added extras should be somewhat similar, on one i looked at - they have small electronic valve that should open and close on demand, but as with most valves and the quality of water available in some areas, they do sometimes fail to open on demand ( ie: when the tray tips over, the valve should open to fill the next tray ) - being blocked, or faulty would prevent any water from running in.
I myself have not worked on these types of appliances much recently, and technology changes all the time, so it could be worthwhile to have either:
  • A repair center come take a look at it for you.
  • Allow time for a second solution to be offered by other fix ya experts.
Now people with more relevant experience in these areas may also tell me i don't know what i'm talking about, and rightly so, but this is just one solution offered and i can't always be spot on, especially if the make & model is not specified.
In my opinion, usually a little expertise can go a long way and save some hard earned dollars also, so bearing in mind - sometimes we have little or no option but to place ourselves at the mercy of repair centers, who just so happen to deal with these kinds of problems on a daily basis.
Posted on Feb 05, 2008
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Icemaker not making ice
check your fill tube
it might be frozen solid
Oct 02, 2009 | Refrigerators
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Icemaker
check the water inlet valve in the rear of the refrigerator/// do you have a water dispenser in the door?? if so switch the wires and see if the im then fills when pressing the water disp button
Mar 15, 2008 | Sub-Zero Bottom Freezer Refrigerator
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
