Magic Focus does not work. - Televison & Video
  • Jimmy1975 Mar 15, 2008
    Magic Focus is not working on the green. You can see the green move as it tries to focus.
  • ladywinn
    ladywinn May 11, 2010
    Need to know your make/ model /number in order to be able to help you out. Have a nice day!
    Genius:
  • 1,694 Answers
Magic Focus will be restored after repairing convergence circuit.
Requires replacement of STK392-110,120 or 150 IC's with new
up-grade STK394-160 Hitachi # CZ 01341.Also,check current
limiting resistors for over-heating....Your comments,please..
.......................T.
Posted on Feb 21, 2008
Magic focus on my 60" Hitachi isn't working.
If your magic focus is not working your convgence has failed. Read this Tips page here on fixya for more details.
Jan 22, 2013 | Hitachi Televison & Video
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Magic focus works briefly, then the tv is out of alignment
You need to replace the convergence chips and possibly some of the convergence resistors. You can buy the parts online from various sources or you can get a complete kit with instructions from www.TvRepairKits.com
Apr 19, 2009 | Hitachi 53UDX10B 53" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
with upgrade Stk394-160E Hitachi part # CZ 01341,change both
for reliability.....check B+ feed resistors for over-heating....T.
Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Magic focus
That's a DP23 chassis, why replace the deflection board? Does magic focus come on the screen? Does it just no converge the picture? If so, it's likely that the convergence amps have failed.
That unit takes two STK392-110 Sanyo built Ics at board position Ic04 & Ic05. If you replace them I'd upgrade to the STK392-150's for greater reliability.
Bill
Dec 13, 2007 | Hitachi 51F500 51" Rear Projection...
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
