Question about Frigidaire ATF6000ES Front Load Washer
E20 I HAVE TO KEEP PUSHING THE START BUTTON AND SOMETIMES UP TO 3 TIMES DURING A WASH. SOMETIMES IT TAKES 2 HOURS TO FINISH A LOAD. SOMETIMES WHEN I START IT AGAIN, IT DOESNT PICK UP THAT TIME IT STARTS ALL OVER...... I CANT FIND MY MANUAL SO THAT I CAN LOOK UP THIS ERROR!!!!!!
  • 1 more comment
  • Anonymous Aug 26, 2008
    have to reset start button 3 to 4 time per wash. it stops and want start again until I push the buttons
  • Anonymous Sep 10, 2008
    I have a one year old Affinity washer that is showing an E20 code. It is on the rinse/spin cycle and won't drain. Everytime I try to restart the cycle I just get a horrible grinding noise. No E20 code in the manual. Any ideas??
  • Gary Davd
    Gary Davd May 11, 2010
    I have the Manual and there is no E20 Code
    This may help
    READING ERROR CODES:
    1. Wake the washer by pressing any button.
    2. Wait 5 seconds.
    3. Press and HOLD the Start/Pause and Cancel
    buttons simultaneously. As long as the buttons are
    held, the failure code will appear in the display as an
    E
    followed by two numbers, a number and a letter or
    two letters. The controlwill beep and the Door Lock,
    Wash, Rinse,
    and Final Spin indicator lights will
    flash.
    Quick Check
    If there is no error displayed and thewashermomentarily
    starts then turns back off:
    1. Listen for a relay closure inside the motor control
    shortly after the Start/Pause key is pressed. If this
    happens, themotor control has power.
    2. Check the 5 pin connector wiring between the
    console control and the motor control.
    NOTE:
    During normal operation, the displaymay show:
    “SAn”
    - deep clean (Sanitary Cycle)
    cd” - cool down (Sanitary cycle)
    do” or “dr” - door problem.
    Err” - an error has been detected.
    LOC” - control lock is activated.
    PAU” - cycle has been interrupted.
    To clear latest stored error code:
    • Turn the Program Knob to the start position, Spin
    Only.
    • Press Start/Pause to start the cycle and save it.
    • Press Cancel to stop the cycle and turn off the
    LEDs.
    • Press Cancel again to turn on the LEDs.
    • Within 5 seconds, press and hold the Option and
    Start/Pause
    buttons until LEDs start sequentially
    chasing, then release buttons.
IF IS MAKING A NOISE THAT MEANS THAT THE PUMP IS STUCK, TAKE APART AND I BET YOU THERE IS SOMETHING , A COIN OR SOME METAL THAT DON'T LET IT TURN. I HAD THE SAME PROBLEM AND I FOUND A HAIR PIN STUCK IN THE PUMP.
Posted on Sep 29, 2008
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Duet GHW9150P Front Load Washer: During washing cycle it stops and beeps with the l...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
My washing machine keeps giving me a error 20 code and dosent finish the cycle
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Too many E20 errors!
the first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
Aug 03, 2017 | Zanussi ZWD1680W Front Load Washer / Dryer
Frigidaire ATF6000ES Front Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
