Question about Uniden EXS 2080 Cordless Phone (EXS2080)
Uiden cordless phones
Model 2080, I have purchased 3 additional uniden phones for my home and am having trouble following the owner's manual to register a handset to another base. We need the procedure following article #2 as given in the owner's manual. Pg 21
In procedure # 3, press menu handset, fails to give a way to select register base menu. From this point, I need clearer instructions. Phone # is 310 454-4740
Thanks
  • wxyzy Feb 05, 2008
    Need help setting up accessory phones Uniden 2080. thanks
    Need help with understanding the set up instructionp 21 for setting up accessory phones.
  • 98 Answers
SOURCE: Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
Posted on Nov 23, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
  • 5 Answers
SOURCE: Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Posted on Mar 19, 2010
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
How do I set up the answering machine model DECGT 2080-5
To set your answering machine, please refer to page 38 of the owner's manual. Here is the link to your manual: http://www.uniden.com/pdf/DECT2080om.pdf
May 20, 2015 | Uniden DECT 6.0 Cordless Phone ID
How do I set up the answering machine model DECT 2080-5
May 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I set up greeting? I have a Uiden cordless 5.8GHz. Thanks, Fran
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 07, 2010 | Uniden Cordless Phone
Need a user manual download for Uniden Dect model 2080-2
Select your phone's model from the list at
http://uniden.com/index/manuals_results.cfm?cat=59
Jul 11, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden omega 2000 & 200 (my model : OMEGA 2080)
May 31, 2009 | Uniden Cordless Phone
I'm looking for a Uniden 2080 manual I can download. If available please let me know pschery@optonline.net. THANKS
I just purchased a Uniden cordless Dect 6.0 2080 W. If there is something you would like to know about I can look it up and e it to you. Send2myplace@yahoo.com from wadezplace
Apr 04, 2009 | Uniden Lands Phones
Uniden 2.4 GHz cordless phone
The manual is at http://www.uniden.com/pdf/EXAI2248om.pdf
Sep 06, 2007 | Uniden Cordless Phone
Uniden EXS 2080 Cordless Phone (EXS2080) Logo
126 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
