Question about Acer AL1511 15" LCD Monitor
The screen starts up too slow
When I shut the screen off and turn it back on it takes about 5 to 10 minutes before it turns on. It continue to flash Acer signal without showing the actual screen. Is there some way that I can fix this?
thanks.
  • 98 Answers
Unscrew your lcd monitor then check for loose connections. if you know how to solder check the circuit board for loose parts..
Posted on Feb 05, 2008
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
Htc evo 4g turned off and wont turn back on and is flashing orange and green lights
That ussually means the battery is overheating! Take the battery out and wait 30 minute to put back in, but don't turn the phone on. Start charging it again, and if it continues to flash, take it to your provider IMEDIATLY!
Jul 14, 2013 | HTC Cell Phones
Just replaced lamp/housing and now tv turns off after 2 minutes of being on. Green light flashes continually(about 30 sec.) then tv turns back on and the cycle continues. The tv is a sony bravia...
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 17, 2011 | Sony KDF-50E3000 Television
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Screen turns off and on continuously
check the solder on the vertical output ic. it may need to be resoldered
May 11, 2008 | Sony KP-48S65 48" Rear Projection...
Acer AL1511 15" LCD Monitor Logo
179 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
