Question about AMD BALANCE A535 NOTEBOOK MOTHERBOARD WITH 1600+ PROCESSOR BULIT IN - (F27014F43704341)
Power plug on laptop not working
Power plug on laptop broken I need to repair or replace the connector. is there a field service manual to open the laptop and view the problem area?
  • 92 Answers
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating systempower plug on laptop not working - 1.gif.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
Posted on Feb 07, 2008
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
How do I get at the power input connector to replace it?
Dear,
Only the authorized service provider can give you the exact power connector. Please contact them
Oct 15, 2009 | Medion (md 40274) PC Notebook
Replacing the keyboard
your only supposed to pull the hinge out carefully a small amount so the flex cable comes loose, then insert the new keyboards connector there and push them back into place. Its pretty much the same thing in all brands of laptops.
if you have broken the connector, you will probably be looking at buying a new motherboard unless you find someone to replace the broken connector.
Oct 11, 2009 | HP Compaq Presario R4000 Notebook
The dc power plug is broken
Yes.
Is the connector on the power adapter that plugs into the laptop?
If so, this is an easy repair, purchase a new connector from electronics parts shop, cut off the old connector and solder the new one on the end of the cable. MAKE SURE YOU SOLDER THE CONNECTIONS TO GIVE THE CORRECT POLARITY ON THE CONNECTOR, OR YOU WILL DAMAGE THE LAPTOP.
If the power socket on the laptop is faulty, this repair is more difficult. The socket may only need resoldering on the motherboard or in the worst case a new socket replacement. Either way the laptop need to be dismantled to get at the power socket.
If you don't feel you can handle this, get it done by a computer repair shop or a techo friend.
May 28, 2009 | Computers & Internet
Hi , i m arhan khan .... plz send me dell service centre contect number & address in Delhi ...... my email ID 's mohdnoumaan2588@yahoo.co.in
Dell Laptop Service Centre in Delhi. Call Laptop
Call Laptop Clinic for genuine repairs of Dell Laptops.Pickup and delivery service at your doorstep.Just call or
Dell Inspiron,Vostro,Lattitude or any other model of Dell ,Laptop Clinic is a division of Beyond Computers, the most trusted name for the last 16 years.
.hidden {display: none;} .invisible { visibility : hidden; }
  • Dell Laptop AC power connector, broken, damaged, Loose, bad Motherboard ?
Having a Laptop problem? your computer does not boot-Up ?Laptop Clinic can repair a broken or damaged Power Connector. Give us a call at 098111 37536; it is possible to repair the connector assembly without replacing the motherboard.
  • Dell Laptop bad display, LCD Screen Broken or very dark display, No Display ?
If you have a broken laptop screen, You do not have to replace the expensive Laptop screen, it could be one component is bad or a loose cable. Let us check it out for you, before you replace the expensive Laptop screen or throw your laptop away.
  • Dell Laptop Bad Keyboard, or bad CD / DVD Optical drive, Hard drive and CPU Fan ?
We also repair Laptop Keyboard, CD / DVD optical drives, Hard drive CPU Fan and Housing repair.
Phone : 9811137536
Address : 2879 Sant Nagar Main Road Rani Bagh Near M2K Pitampura New Delhi
website : http://www.beyondlaptops.com
Feb 21, 2009 | HP Pavilion dv6000z Notebook
GATEWAY ta6 WAS DROPPED ON THE CONNECTION FOR THE EXTERNAL POWER SUPPLY (ac adaptar) AND IT MADE THE PIN LOOSE ON THE LAPTOP. I WOULD LIKE TO TAKE THE COVER OFF AND REPAIR THE PRINTED CIRCUIT BOARD AND PIN...
Try here - detailed photos for same problem on different model Gateway:
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Dec 11, 2008 | Computers & Internet
Replacement part for charger plug in on laptop.
The plug for the charger? its soldered into the motherboard. it requires a full disassembly of the laptop.
Just need to find a replacement for it.
you can try contacting http://www.acerparts.com/ with the laptop details for the power connector / plug
you can also look for it on www.ebay.com
computer repair shops should be able todo the job, really no need to replace the whole motherboard, just the plug. Also check is the cord of the power adapter broken? I had to take my power adapter, the black box in the middle of the cord from the wall to the laptop, one cable had came loose inside the power adapter, worked perfectly after I resoldered it in place.
Aug 11, 2008 | Acer Aspire 5610-4648 Notebook
My laptop will not charge!! the charger works, but it just wont charge my laptop!
most likely either a bad connector on the power cord or you've broken the motherboard connector. check the power cord with a volt meeter. if it comes up fine the i would recommend either contacting the manufacture or taking it to a reputable tech. if you are comfortable with doing it you can take the laptop apart and look at the connector with the laptop apart plug it in (CAREFULL IT COULD KILL YOU) and test the voltage after the connector wit the volt meeter. if it has power then most likely *********** board is dead. if it doesn't have power then you need to repair/replace the power connector.
Jul 07, 2008 | Computers & Internet
How can I fix the loose power jack?
The last 2 screws to separate top from bottom are located ynder the 3/8" wide clip on plastic piece above your function buttons. Center screw and right hand side. Be careful of ribbons, plug-ins and wires that attach to both sides. I strongley suggest not doing this if you are not mechanically inclined. You could very easily cause damage to your laptop.
Aug 27, 2007 | Gateway 4530GZ Notebook
Computers & Internet Logo
406 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
