Dlp tv picture flickers and reds have yellow blotches after the TV is on for more than an hour.
  • anshul09 Mar 12, 2009
    I have s ony dlp 50inch flat screen TV - the screen is flckering off and on while the programming is going on.
Could be color wheel problem--but u'll prolly have to change out the light engine $$$--Causes blotches---Good luck
Posted on Feb 05, 2008
Samsung DLP tv white color turned to yellow
go into menu reset picture settings to default
red , tint or gamma is off
Nov 15, 2016 | Samsung Televison & Video
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Panasonic DLP TV has huge yellow blotch covering most of the screen
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
You have a damaged light engine.
Apr 23, 2012 | Panasonic PT-43LCX64 43" HDTV
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
DLP TV keeps flickering
Please recheck component connections in both units and make sure to hook up them according to corresponding colors like blue to blue, red to red and orange to orange.
Dec 13, 2008 | Samsung HLN5065W 50" Rear Projection...
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Dlp picture problems
dear,
if you have checked it by changing the lamp then there you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but dear plz dont touch that one.
regards,
Aug 16, 2008 | Toshiba 46HM95 46" HDTV
Bad picture. in wide
sir kindly adjust its screen focus of your tv,,, thankss and hope too help you,,,gud luck
Feb 25, 2008 | Televison & Video
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
