Question about HP Officejet Pro L7680 All-In-One Printer
HP Officejet L7680
The printer can print in color, but it does not print black text. I have changed the ink cartridge and there appears to be no issue with the printhead.
  • 1 more comment
  • Anonymous Feb 28, 2008
    the HPofficejet L7680 does not print in black text.I have replaced the cartridge but it is still not printing in black.
  • Anonymous Dec 30, 2008
    My printer also stopped printing black.
  • Anonymous Jan 27, 2009
    My Black ink has also stopped printing.
I say change the print head an the cartrige an that should be find
couse i did an my printer is perfect
by andrew
Posted on Apr 04, 2008
HP officejet pro l7850 wont print black
are you using hp original cartridges? if not, then thats probably the issue!
Jun 30, 2012 | HP Officejet Pro L7680 All-In-One Printer
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
hi,
the yellow cartridge is '' Y" and not K , you have a problem with the black carteidge "K" replace the black and tell me what is the new message, i will help you. i'm online
Nov 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Problem Printing Black
Try to reinstall your printer.
Check your black cartridge if they are installed properly.
Replace your black cartridge with a new one.
Aug 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Can't get the black ink cartridge to print
Try taking out the cartridge and inserting it again to make sure it was originally put in the printer correctly and not forced in.
Jan 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
207 people viewed this question
Ben Johnson
