Question about Whirlpool 24 in. DU920QWD Built-in Dishwasher
Rattle Noise in motor - DU920QWD
Our 920 dishwasher is 10 years old and a rattle noise has developed in the area of the motor. Could that be a sign the motor is going or could it be some other problem. If it is the motor, how difficult is it for a handyman to replace it?
  • 2,039 Answers
Its not the hardest thing to do but is it worth it motor price you have to see the rest if its good maybe you invest $150.00 and up you still have that old washer check the price for part dont forget it gonna be rusty in there maybe other thing gonna break if it not cheap motor run it untill it drive you crazy buy a ney one it gonna be quiet and it will be energy star less electricity there not to expensive thank for using fixya pierre
Posted on Feb 05, 2008
HVAC is making rattling noise
Your fan that is attached to your blowermotor is loose, causing the rattle, or the bearings in your blower motor are bad, causing the shaft and fan both to rattle.
Dec 12, 2013 | 2005 Pontiac Grand Am
Jeep 360 rattle sound at idle in park
it could be a wrist pin, and im not sure if those amc's had hydraulic lifters but sometimes with old lifters when the oil pressure is lower at an idle the lifters arnt filling up all the way so they develope a little valve lash, and when the rpms are raised the oil pressure raises and fills the lifters. you could try chasing the noise down with an automotive stethoscope.
Mar 23, 2012 | 1985 Jeep Grand Wagoneer
Rattle noise at 1200 rpm on 2006 silverado
sounds like you have something loose first track were the noise is coming from and inspect the area for loose componets if it is coming from your motor then you might need a mechanic to check it out could be something loose in there
Jan 26, 2010 | 2006 Chevrolet Silverado
Rattling noise from near side front wheel area. Have checked for play on bearing and checked brake disc. No problem detected. Noise only occurs at low speeds.
i have the exact same problem ive got 2001 honda civic and have an annoying rattle from the wheel area. i have replaced cv joint, ball joint, sway bar drop links, strut, and suspension bushing and arm....but still rattle noise is there. dnt have a clue what it could be, from looking on the internet i have found few possibilities.....lower control arm/bushin...motor mounts....gear box mounts....strut rod bushing....axle....inner/outer cv joint....calliper pins......shock/shock bushing...or wheel bearing. im hoping tio get all this checked out its got to be able to be fixed somehow!
Dec 29, 2009 | 1997 Volkswagen Golf
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Same rattle and noise
this is easy one if you put the a/c on do you hear the rattle if yes then shut off the a/c if the noise go away then it is the compressor
Jul 21, 2009 | 1995 Nissan Altima
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
DISHWASHER NOISE
A noise could be created by something getting down into the motor-pump assembly piece of glass, piece of bone, wire tie anything really. If this is the case and you can remove it before it causes further damage problem solved. At ten years old the problem may be the motor and or pump one thing to consider before putting money into it is disheashers average 7-10 years these days. Good Luck.
Jun 02, 2008 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
138 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
