Question about Creative Labs ZEN V Plus MP3 Player
Zen v plus 2gb wont turn off
All buttons and menus work but when turn the player off it reboots itself in about 2sec and starts to play again????????
  • Anonymous Mar 21, 2008
    it want turn off its locked up
    Sergeant:
    Champion:
  • 333 Answers
Have you tried a hard reset? Insert a paper clip in the tiny hole at the left hand side.
Posted on Feb 05, 2008
Hey im having an issue with my zen V plus mp3 player! When I plug it into my computer, the computer doesnt recognize the player and says it is not connected.
What I did was turn OFF my zen C plus, and as soon as I turned it back ON, i held down the play/pause button, the back button, and the select button/joystick. this brought me to that menu that offers unloading the firmware and rebooting and so forth. I selected the first option, which scanned the player; then I rebooted it, and not only did my player read on my PC, but ALL my music came back too! It was sweetness in its form.
Oct 27, 2009 | Creative Labs ZEN V Plus MP3 Player
Nothing works!!
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Aug 10, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery mode
If your Zen is in recovery mode, simply reboot it, and it should go back to its normal screen.
However, if you reboot it and it goes back into recovery mode again, that means there is some problem with your Zen--likely a hardware failure. It will need to be checked out by a technician.
Mar 23, 2008 | Creative Labs ZEN V Plus MP3 Player
Help with zen problem
Push the reset button. This worked for me.
Mar 09, 2008 | Creative Labs Zen Stone Plus MP3 Player
My zEn...
you should not have had to install anything for the Zen to work on Vista. If you have installed any Creative software, remove it. Reboot, plug your player in, open Device Manager, and remove the device that shows up representing your player (completely uninstall it). Reboot again, and plug in your player. It should be recognized now.
If that still doesn't work, then boot your player into Recovery Mode, and perform both a Disk Cleanup and a Reformat. Reboot the player and try plugging it in again.
if it still doesn't try another computer and upload the latest firmware to it and then try it on your pc after firmware is loaded
http://us.creative.com/support/downloads/
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Jan 24, 2008 | Creative Labs ZEN V Plus MP3 Player
Docked prooblem
Plug it in and start charging it. Once it has a decent charge if you ever have that problem again... (see below)
Using the instructions below try Reset, first, if that doesn't fix it try the Cleanup method, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
  1. Detach your player from the PC if it is connected, and turn off the player.
Clean Up
Format (All) Caution! Erases all content!
Reload OS/ Firmware Caution! Erases your player's firmware.
Jan 07, 2008 | Creative Labs Zen V MP3 Player
My creative zen v plus is not detected by my pc when connected its screen has reddish lines neither it is shutting down nor it is working
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
Clean Up
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Jan 05, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V 2gb Plus
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
if that didn't work try this http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Dec 10, 2007 | Creative Labs Zen Touch MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
314 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
