Question about Foxconn 6100K8MA-RS Motherboard
Video no video signal to monitor, tryed different monitor, still nothing, tryed new card still nothing, tryed different cables nothing. this happened 2 or 3 times but on reboot i had video, now i have nothing. any ideas
Hiya's, changing the driver won't help if you cannot get into windows. What is happening is that the onboard chipset has died (overclocking kills em nicely).
You can try adding a video card to the system, tho I suspect that will also be no different, as the board will refuse to post.
Seen too many of these boards doing this, thank god we stopped selling them.
Good luck
Posted on May 16, 2008
    Problem Solver:
  • 17 Answers
Hey..!!there,,
Resolving video card problems can be costly if you opt to replace the hardware when a problem does occur. However, before you take such drastic measures, you should consider other solutions such as updating the driver.Here are some of the common problems that can arisefrom video cards and some suggested...
Posted on Feb 05, 2008
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
My monitor does not bring the bios set up and up saying no input signal what are the solution and causes
Check that the "data" cable is tightly-connected at both ends (monitor & video-card).
Try connecting the monitor to a different desktop/laptop computer, to see if the monitor works at all.
Try a different "data" cable between the monitor and the video-card;
obviously, your monitor's "power" cord is working, and thus, there's no need to swap that cable.
Try connecting a different monitor to your computer, to see if your video-card is transmitting any signals.
Temporarily swap-in a different video-card, to see if the video-card is the problem.
If all else fails, take the computer to a technician at a computer-store.
Aug 16, 2010 | HP w1907 LCD Monitor
When turning the screen on, the light turn green but then turns orange and nothing comes on the screen
This means that the monitor is not getting a signal from the computer. The problem could be the video or graphics card or it could be the monitor itself.
Try to connect the monitor into a known working CPU. If the monitor works, then you need to check your video card.Try to pull out the card and clean it using a DRY clean cloth. And then re-seat the card to the slot. If nothing happen, insert the card into an available video slot. or try different computer. If same problem occur, contact the manufacturer.
NOW, if the problem is the monitor, check the cable, try to use different video cable. If same problem occur, then it should be checked by a technician.
Thank you and good luck!
Jun 28, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Monitor display no signal message
Hi. Check the cables if it is firmly connected to the video ports. If nothing happens, try removing and reinstalling the video card then reconnect the cables. It works wonders!!!
^_^
Jun 03, 2010 | HP w2207 Monitor
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor shows VGA no input signal DVI no input signal then monito going to sleep
This sounds like a video card driver issue or the card it self. Make sure all cables are plugged in snug. Once done try to boot in to safe mode by restarting the computer and while it is starting keep on tapping key F8 and choose safe mode. If this works it is driver issue. If nothing happens it is the card it self. Might have to take it to a authorized repair shop. Hope this helps.
Feb 15, 2010 | HP Pavilion A6400f Desktop PC, Refurbished
Monitor not getting info from computer
Does the computer beep when it starts? Does the monitor work on another pc? Possible culprits with these symptoms are the power supply and video card.
Feb 16, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Reverse KVM problems
If you are sure the left monitor?s power is not the source of the problem it does sound like a shielding or excessive signal loss in a device/cable. If it?s always the left monitor I would try unplugging the video cable that goes from the left monitor and plug it into the right monitor; do the same with the other monitor. If the problem moves to the right monitor then that eliminates the monitors and we move on. If the problem goes away then probably one monitor had more signal degradation than the other. If the problem stays then the monitor is the source of the problem. If the problem followed the cable then I would exchange the cables that run from the switch to the monitors; if nothing changes exchange the cables that run from the switch to the PCs. If exchanging any of these cables results in the problem moving then you have a damaged cable or a bad connection. If the problem is still on the left monitor unplug the cables from the left PC that run from it to the switch and plug them into the right PC; do the same to the right PC. If the problem moves then you might have a damaged switch OR perhaps the video card output on one of the PCs is weaker than the other. All cables and devices weaken the video signal to some degree but the amounts can differ wildly. Over the years I?ve had this problem caused by cables, switchboxes, video cards, radio transmitters, bent connector pins, poor connections, excessive cable lengths, monitors and accumulative signal loss from several devices. The last is the hardest to diagnose. Good luck and let us know what happens.
Jan 01, 2007 | APC Cables - KVM Products, Data Switches,...
Foxconn 6100K8MA-RS Motherboard Logo
118 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
