Question about GE 25952 Cordless Phone
"Do Not Disturb"
I've somehow managed to accidentally set the "Do Not Disturb" function on  my phone and now I need to know how to undo what I've done...  Help!
  • 1 more comment
  • Anonymous Mar 28, 2008
    Same problem and i cannot dial out or receive phone calls. And *79 does not work because i cant dial the * .
  • sissy99 Jun 24, 2008
    The do not disturb is on and when i push to turn it off it want what else is there for me to do to get it off?
  • sandywo Aug 20, 2008
    I have a radio shack 5.8 GHz cordless phone. The do not disturb is on and I can't get if off. There is no button on either of the bases or on the phones. I don't even know how it got turned on. Do you have any suggestions
    thanks
    sandy
On the base unit, press the "Do Not Disturb" button. This button is located on the front right corner of the base unit. The button light should turn off indicating that the DND feature is deactivated.
Posted on Jun 21, 2008
Do you have Insight telephone Service? If you do then try pressing *79.
Posted on Mar 21, 2008
Phone says "Do not Disturb" and will not ring
If you have an iphone, you have your setting set to "do not disturb" which will silence calls automatically which is a great feature for times when you are in a meeting or even a movie theater.
I'm assuming you have an iphone which is the most common phone and easiest to accidentally turn this mode on. If so, go into your settings and underneath the "notifications" and "control center" tab, you will see "Do Not Disturb". Switch off the "manual" tab as well as "scheduled" if that setting is on. Now, your phone should ring like normal.
Hope this helped!
Mar 11, 2016 | Lands Phones
Why can't I send or receive calls?
This is a shot in the dark without knowing more details, but have you checked to see if the Do Not Disturb setting was accidentally turned on?
If you have an iPhone, go to: Settings + Do Not Disturb
If you have Android (depending on the phone) check Settings + Sound & Notification + Interruptions
Let me know if none of this works and what kind of phone you have
Jun 07, 2015 | Lands Phones
How do I unset the "do not disturb" function.
Hi Jill, I'm assuming you're using an iPhone with the latest software update here: you should be able to go to Settings + Do Not Disturb and edit your preferences there. Let me know what phone/ version you are using if this does not help
Jun 07, 2015 | Uniden Lands Phones
Do not disturb has been set. Need to take it off
Since you neglected to specify the model of your Uniden 5.8GHz cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 31, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Phone set on do not disturb can not undo
For GE 6.0: There is a button on the base (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz: 1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Nov 12, 2008 | Uniden Cordless Phone
Features
Not sure how you set this feature but here is the solution:
To set DND you would have pressed your feature button, 60,and then feature button again (if you were forwarding to another extension you would have had to enter an extention after 60 and then the feature button. This sets your DND or call forward.
To eliminate press feature, 69 and then feature again this should cancel the call forawrd or do not disturb.
Oct 01, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
Do Not Disturb
hahahaha Thanks for the advice! I've been trying and trying to fix this problem for days now. "Do not disturb" button - wow, do I ever feel like a ****.
Sep 05, 2007 | GE 28112EE2 Cordless Phone
GE 25952 Cordless Phone Logo
220 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
