Repair tv my rca tv model number p46720lv has a blue thing in it that fades in and out and now the tv is making a clicking sound then after awhile it will shut off by itself. i would like to know how to fix it or how to get a free service manual for this.
  • 5,138 Answers
Go to www.free service manuals type in your make and model number they should have one, some information you have to pay for depending on how new/old your set is! Also i hope you do understand that your television does hold a charge of 46,000 volts up to 49,000 volts so unless you know how to repair this my advice for you is to take your set to a tv repair shop! this is no easy fix it yourself deal. Thank You for asking fixya.Have a nice day.
Posted on Feb 05, 2008
Blue screen rca tv model 14f512t
you will have to take it in to get repaired. might of put a speaker or something megnatic near your tv.
Oct 21, 2012 | RCA 14F512T 14" TV
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
RCA TruFlat 32" Blue light flickers, clicking noises, help!
OK for the start, try this unplugged your unit for about 60 sec. Then plugged it again and switch on. Does it help?
If not then dont connect your surge protector in line for the meantime. Power the unit. This is to isolate whether your surge protector is defective or not. Does it help?
If not, this could down to your high voltage section, if this is a crt tube tv. You might loose your flyback transformer, and or the horizontal output transistor. Checking its peripheral component is a must. That clicking noise is the relay, thus this have relay?
If your not into electronic, have it service.
Apr 28, 2009 | RCA TruFlat 27F520T 27" TV
Rca ctc203 model number f25305 no sound
replace La7612h this is the audio amp ic.
Jan 11, 2009 | RCA F25305 25" TV
RCA big screen
More then likely your blue tube is bad.repair cost 350.00 and up.ThankYou for using FixYa and Have a Nice Day.
Feb 05, 2008 | Televison & Video
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
222 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
