Question about Alpine CDA 7893 CD Player
E brake I'm trying to hook my radio up but i don't know where to hook up on the e brake so my video will show
  • 24 Answers
TO BYPASS ANY RADIO/DVD PLAYER SAFETY SWITCH RUN TOGGLE SWITCH FROM WIRE AN OTHER END GROUND TURN ON UNIT THEN PUT DVD IN AND FLIP SWITCH ON AND OFF 2 OR 3 TIMES MOVIE WILL POP ON AN STAY ON REPEAT MAY REQUIRE IN FUTURE USE
Posted on Mar 07, 2008
    Master:
    Sergeant:
  • 440 Answers
To safety break green wire then ground it usally how they do it
Posted on Feb 05, 2008
I can not get the video to play on the screen
there is a ground wire that go's to you park brake make shur it is hooked up and the park brake is on if that is not hooked up right it wont work. if you tryed to bypass the park brake every time you turn on you radio to paly a video you have to unground it and then re ground it for it to work
Jul 21, 2011 | Pioneer AVHP3200BT Car Video Player
Sound works but there is no display on the monitor. it worked for the first few days then now cant see nothing. Does the park brake wire have to be hooked up in order to show the display cause i know it...
  • Yes it does. The emergency brake wire is a safety feature. If you don't have it hooked up it won't even display anything. If you do have it hooked up then you have to have the emergency brake engaged to be able to view DVD'S. The manufacturer does this so people can't just unhook the brake wire and watch DVD'S while driving
Regards, Tony
May 20, 2011 | Pyle PLD61MU Car Video Player
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
How do i hook up my parking brake
in the directions it should either tell you to attach a wire from the radio to the ebrake so you can get video. i dont like that idea . first try and ground and ground the wire to the back of the unit. some manufactures incorparate a sequense ex- pull e brake three times then the video will work . what i have done with these is put a small button in the center console or somewhere out of the way . if you want to hook it up the way they want it i need to know what kind of car you have ...
Jun 19, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
How to Bypass E-Brake Screen For In Dash DVD Player?
There should be a green wire if not the wire that states to hook to the e-brake hook to a hot 12v source and that should fix the problem. You may have to ground that wire instead depending on the model.
May 22, 2009 | Clarion VRX485VD Car DVD Player
DP Video car system to play video
look at the install diagram(wiring codes) that came with the unit. if it has a wire that's designated for the parking brake (allowing you to only watch dvds while brake is engage) take that wire and instead of hooking it up to the parking brake, ground it or put an in-line switch between wire and ground so you can turn that function on and off. warning!!! watching while driving is illegal in most states
Dec 30, 2008 | Panasonic CQ-DVR909U Car DVD Player
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
Alpine CDA 7893 CD Player Logo
98 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
