Question about Canon Pixma MP450 All-In-One InkJet Printer
Error Code 5010
I am getting a error code of 5010 on my printer. Any idea what the problem is? I don't have the manual and I just bought it used.
  • dwr7 Feb 23, 2008
    I am getting the same problem error 5010. I just read the solution given to the other person having the same issue but unless you are some kinds tech whiz it means absolutely nothing to me and doesn't help solve the problem. Any ideas on an English translation of this solution jargon? or is there an easy fix out there? Thanks.
  • 4 Answers
This behavior can occur because the Setup program is attempting to locate the Microsoft Exchange System Objects container, but cannot locate it. This behavior can occur because the objectclass attribute that the Setup program is attempting to locate is msExchSystemObjectsContainer. The Setup program then attempts to create an Exchange System Objects container by using the proper class type. However, the object already exists, and a new one cannot be created
To resolve this behavior, rename the organizational unit to something other than "Microsoft Exchange System Objects". To view the objectclass attribute, either use ADSI Edit or LDP. Note that if this organizational unit has the objectclass of msExchSystemObjectsContainer, this organizational unit cannot be renamed.
WARNING: If you use the ADSI Edit snap-in, the LDP utility, or any other LDAP version 3 client, and you incorrectly modify the attributes of Active Directory objects, you can cause serious problems. These problems may require you to reinstall Microsoft Windows 2000 Server, Microsoft Exchange 2000 Server, or both. Microsoft cannot guarantee that problems that occur if you incorrectly modify Active Directory object attributes can be solved. Modify these attributes at your own risk.
Posted on Feb 05, 2008
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
Feb 05, 2015 | Canon PIXMA MP830 All-In-One InkJet...
How to clear error code 5010 on canon pixma mp460 all in one printer
Check the manual that came with it for the answer to the codes.
Jul 20, 2014 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5010
Canon only lists three 4-digit error codes for the MP500: 1700, 1851, and 1856. After much research and finding many other MP500 owners getting this same strange code, I have come to conclude that it's the code of DEATH. Sometimes you may get strange codes if using compatible ink cartridges. Unless you can get the printer to reset and clear, the only other thing to try is to go back to the Canon driver download page and reload the correct driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Apr 25, 2010 | Canon Pixma MP500 All-In-One InkJet...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
Sep 02, 2017 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5010
There's no specific info on a 5010 error even on Canon website, but ANY error in between 5000-9999 needs Canon's attention, so if it's under warranty, get a replacement.
Feb 17, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
410 people viewed this question
old marine
old marine
