Question about Samsung SyncMaster 740N 17" LCD Monitor
Prob with screen resolutions
Just a simple prob i guess with screen resolution on my samsung syncmaster 740n, it seems to be that i dont have the option to set the resolution 1024x768. I only have the options for 800x600, 960x600,1088x612 and 1280x720. I tried choosing other refresh rates but what it did is added lower screen resolution but still no 1024x768 option. Im using Nvidia Geforce 6200LE, tried updating driver still no luck
  • pestilence Feb 05, 2008
    Woah thanks i guess i just need this file to fix it..i've tried the cd that came with the monitor but it didn't fix the problem but the file you posted on your message did the job!! You are a GURU thanks Kudos!!
    Brigadier General:
  • 6,966 Answers
May I suggest working on the monitor itself before tackling the video card.
To my understanding, your monitor came with an installation CD that contain drivers/software for your OS to recognize the LCD correctly. Should you need a downloadable copy, its filename is 20050615115516359_SM740N.exe.
If you have already installed the monitor's drivers and updated your video card's driver as well, and problem persist, you may need to work on the AGP or PCI-E of the motherboard itself. Pls post back motherboard or PC's brand and model.
Hope this be of help. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 05, 2008
  • Louie  Role
    Louie Role Feb 05, 2008
    Hi again,
    You're more than welcome.
    Am glad to be of assistance and appreciate the rating.
    Cheers.
How to improove resolution for Monitor SyncMaster 740N?
The maximum resolution for that particular monitor is 1280 x 1024 resolution. If it is set to that resolution you cannot go higher than that on an LCD.
If your resolution is lower and you cannot make it go any higher check your graphics card and see if your crad can go that high. You also may want to check and make sure the proper driver is installed for your graphics card
Nov 16, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Low resolution
You will be able to increase the resolution of your desktop by going through my published guide entitled How to set your Desktop Screen Resolution?
All the best!
damnor01
Sep 07, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Resolution problem
reset your computer and press F8 F8 immedeatly and keep pressing untill menu appears .then highlight on enable vga mode and press enter your problem will be solved thenk you
Jun 25, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I need minimum 1024X768 resolution but this resolution is not there.. can any one help me what to do... should I have to upgrade if so than where to upgrade?
Below is a site where you can get your info http://www.samsung.com/sg/consumer/detail/support.do?group=computerperipherals&type=monitor&subtype=lcdmonitor&model_nm=740N&language=&cate_type=all&mType=UM&dType=D&vType=&cttID=424827&prd_ia_cd=05020100&acc_ia_fl=&disp_nm=740N&model_cd=LS17HALKB/XSS&menu=download&menu2=detail Hope this helps. Display Screen Size 17" Resolution 1280 x 1024 Brightness 300cd/㎡ Contrast Ratio 700:1 Response time 5ms Viewing Angle (Horizontal/Vertical) 160˚/160˚ (CR>5) Features Plug & Play DDC 2B Multimedia Speakers No Dimension Product Dimension (With stand, WxHxD) 366.0 x 379.3 x 200.0mm (Simple) Weight Product Weight 3.4kg (Simple)
Oct 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Display Problem
video card may not be capable of that resolution and color depth, check your video cards max resolution and color depth.
I have several lcd monitors that are 1280x 1024 and they do not need drivers to work. the video card must be capable of generating that resolution.
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
options listed would be correct for that monitor if you installed the drivers and inf file for the display. if it is another monitors resolution settings then you may just have the wrong monitor installed
Jan 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Awfull colors and very dark at 320x240
hello JareX Perhaps as far as I can tell you that your screen does not suppeot this resolution
Jan 20, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
162 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
