I cant use most features because the remote doesnt work.were can i find a new one or a compatibl multi remote(tried several)ilo dvd recorder
1906 is the numeric code for the philips remote control previously listed
I finally found one that at least worked for the main features. It is a Philips URC from Walmart SRU3004. The guy there said Philips ones run the Ilo. After returning MANY ones that didn't work, I really didn't believe him but he was right. Its not the code listed, you have to do the manual search and it is like the 300th push on the power button so don't give up too soon. The input button operates the Source and the sleep button will get you into the record settings. you have to figure it out but allows you to actually use the unit. It is worthless without a remote. This remote actually works my tv, other dvd and home surround too.
i need to buy a new remote for the ilo dvd recorder
The remote will not work. I have replaced batteries with new batteries and it still does not work. Is is possible to find a new remote for this player?
If so, where do I buy it?
I also cannot find my manual. Would it be possible to obtain a new manual?
I also need a replacement remote, anyone know where I can purchase one?
Need remote control. recorder won't do much without it.
Respond to [email protected]
I have a problem with my ilo progressive scan recorder also. Everything works on the controller except when I go to change the recording setup. I put it on 1 hr. a while ago for something, now I can't change it back! I'm stuck here and am not able to change the setting! Will the Phillips controller change the setting for recording under the setup?
lost the remote to my ilo dvd recorder, where can I get another one?
