Power supply will be the first palce to look, it should have 5,12v, and 24vdc at the output connectors. Look for bad caps with bulging tops, burnt parts, blown fuse.
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Hello, Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Relative to Olevia TV Power Supply Problems Solution provided by: kb8tez Matt, the problem he had was Electrolytic Capacitor CS21. Upon careful examination of the Power Supply Circuit Board I find that CS21 is in parallel with CS22. Simply replacing BOTH Capacitors makes for a more permanent fix. Radio Shack P/N 272-1032 1000UF 35V Capacitors @ $1.59 each plus tax makes a very inexpensive repair. Apparently the same power supply circuit board is common to many different Olevia Models.
the remote control code for DirecTV with Olevia 242T or 237T (37' or
42') model is 11610. this code will power on/off and volume up/down the
buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
