Question about RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf System
Alarm for some reason all of a sudden the music turns on at 4:54pm every day, i did not set it to do this. how do i make it stop?
  • gravedigger1 Feb 05, 2008
    RCA RS2652C 5-Disc CD Changer Bookshelf System
    Problem Solver:
  • 22 Answers
As im seeming to tell every1..lol (make/model plz)
Posted on Feb 05, 2008
  • Brad Drenc
    Brad Drenc Feb 08, 2008
    ok, press and hold the "timer" button to turn on/off the timer...that should do ya, good luck
How do I set the alarm on this model, which I cannot find any where. Grateful & puzzled. Model 7-4806A GE Clock Radio
if I could see a good picture of it perhaps I could assist . most have a slide bar to turn the alarm on then you use the hour or minute buttons to set .
Mar 18, 2016 | Audio Players & Recorders
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Hmdx eclipse alarm clock's alarm stopped ringing
There could be a number of reasons for this happening. Does the clock run only on batteries or batteries and electricity? It could be the age of the clock. The way the clock has been taken care of and the type of environment it is in for example too much dust. If the clock runs on batteries, have the batteries ever leaked and been left in the clock? Take very fine sandpaper and very gently sand the contacts of the clock where the batteries go, dust with a small dry paintbrush and use good quality batteries.
Feb 04, 2013 | Homedics HMDX Eclipse Alarm Clock - Black
Alarm on my 2002 F250 started going off all of a sudden while parked and unlocked. the only way I could make it stop was disconnecting the batteries. what's wrong with my truck?
First, take the battery out of your key fob. All of them. Then hook the battery back up on the truck. If alarm doesn't go off, put battery in one fob. Check it out, all functions. Then check the other one. If alarm goes off when you hook truck battery back up, look for a shorted switch to whatever you alarm monitors and sets an immediate alarm when the switch is closed (or opened). If you still can't locate the reason for the alarm, consider replacing the alarm system, but not before you come back here and tell us what happened.
Sep 17, 2012 | Cars & Trucks
Can't turn off the alarm
There are two alarms, and the steps are the same .
Look on the face. On the left of the big numbers are two symbols, a 'bell' and a 'music note'. That's WAKE 1. On the right of the big numbers are two symbols, a bell and music note. That's WAKE 2. If any of these are on, then one (or both) alarms are set to repeat.
Stopping repeat Wake 1 alarm. Click the Wake 1 button (on the top) several times, while looking at the face. Notice the circles that light up. It will switch back and forth between bell and music note each time you press the Wake 1 alarm button.
HOLD DOWN the WAKE 1 button on the top, until both lights are off. The Wake 1 alarm is now off.
Wake 2 alarm: Same steps, but for the green circles on the right side of the face.
Get a piece of paper, write "HOLD DOWN WAKE BUTTON to stop repeating alarm" and tape it to the back of the clock.
May 07, 2010 | GE 7-4853 Clock Radio
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
My 2004 Lincoln Towncar Signature suddenly developed this habit of setting off the alarm for no reason at all. No wind, no one touching it, etc. How can I bypass this alarm?
Mar 10, 2009 | 2004 Lincoln Town Car
Setting the alarm?
After several iterations with only time/chime/chronometer showing up, my husband hit mode, got chime, hit start stop and suddenly there was Alarm 1. We have yet to get Alarm 2 but hope to some day.
May 23, 2008 | Timex 1440 Nylon watch
No sound
other than just double checking your switches settings there really isn't much you can do ,as there really isn't any easy to replace parts inside and that would be cost prohibitive anyhow , but do remember it is a clock radio , if its set t o use the alarm the radio will not work and not the cd either , ck all your switches for proper setting , one may have got bumped by you or cleaning staff
this is the reason I use a sound bar/phone dock as I use it to charge my phone and play music all day at my desk , they only cost about fifteen bucks to buy , and best thing is there's nothing for anyone to mess with when im not there as it wont work without my phone docked in it !!
Feb 18, 2007 | GPX D725 Clock Radio
RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf System Logo
62 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
