Question about Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset
Caller id model #kx-tga560m phone caller id does not work. We have 2 unit phone 1 phone caller id is working and the other phone did have caller id but has quit working. Is there something we can do to fix issue?
  • 1 more comment
  • Anonymous May 18, 2008
    I have 4 of these devices and only on has the display showing properly.
  • Anonymous Sep 14, 2008
    I have the same problems -- the caller id screen was intermittent for awhile on both handsets and now both screens are completelty blank
  • Anonymous Jan 12, 2009
    my caller id quit. each message tells me "local call."
The digital answer machine did not torn on? Why?
Posted on May 08, 2008
6ya staff
SOURCE:
Caller id stopped working
Dial *31# followed by the phone no and send and see if it would show the id, if it shows i will tell you the next step
Apr 26, 2016 | Panasonic NEW Expandable Digital Phone...
I suddenly have no Caller ID name, number and announcement. I have tried the manual that came with the phone. model KX-TG7624SK 6.0 Bluetooth Talking Caller ID Panasonic. I am tired of answering "cour
Ann also check with your telephone line provider for the land line calls that the subscribed service has been activated that forwards the calling line identity to your land phone line. Could be it somehow has become lost accidentally by the phone company.
It would be worth them checking it has not fallen off your subscriber settings to eliminate it as a possible cause)
Talking Caller ID Handset Dial #162 1 on 0 is off
Base Unit caller id Dial #*162 1 on 0 is off
Guess this toggles it from 1 or 0 in the settings
Jan 27, 2015 | Panasonic KX-TG7624SK DECT 6.0 Cordless...
Talking caller ID Want to turn it off on base unit!!
You have to press "Menu" "#" then 1 6 2.
You can also just press menu and then scroll to talking caller id, select it and then choose to turn it off. Be sure to press "save" or the your choice will not be saved.
May 17, 2009 | Panasonic KX-TG1033S Cordless Phone
2 Problems: #1Volume fades out. #2No caller ID on Call Waiting
1. move closer to base
2. you must have call waiting ID for that to work at all and most of these phones don't use it during active calls.
go to page 21 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 05, 2009 | Panasonic KX-TG1033S Cordless Phone
Caller Id not working KX-TG6323PK
Don't mind. Returned the product to the seller. Thanks.
Jan 11, 2009 | Panasonic KX-TG6323 1.9 GHz Trio 1-Line...
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Using Fixya.com
Oct 10, 2008 | Panasonic KX-TG2357 Cordless Phone
I have a Panasonic KX-TCA132E but no instructions. I have set up with my phone company for incoming caller id to be displayed, however it is not working. Do i have to use the handset to activate the...
I have had this phone (twin) for quite a few years . If your incoming line supports caller ID it should work immediately. I never had to activate this. I would check if caller ID on your line is working. Check with another phone if you can.
Aug 13, 2008 | Lands Phones
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset Logo
678 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
