52 inch sony rear projection t.v.
I have a 53 inch sony rear projection t.v. thats about 8 years old. The set turns on, the screen is green, the sound works for a few seconds and then it makes a whinning sound and shuts down. The red light on the front display keeps blinking. Is this set worth fixing and if so what do you think it might cost.Thanks so much for your input. exibitman47@yahoo
  • 113 Answers
Whining sound most likely is a bad flyback transformer. You are probally looking at a 350-450 bill depending on the repair shop. If your picture was "great" go for it. If the tv has a lot of wear let it go. Nothing the repair shop does to fix your problem will make your picture better than it was before it went out. Somthing to contemplate.
Posted on Feb 05, 2008
Poor Color Sony XBR 52"
Ur coolant is out,must replaced, try this website for coolant.Tv repair World.com
Dec 09, 2009 | Sony KP-53XBR300 53" Rear Projection...
I have a Sony 47 inch rear projection tv that is about nine years old When the set is turned on it has a good color picture but after a few minutes it tuns to a complete green sceen. Can you tell me what...
The green CRT may be intermittently bad or the focus screen block. Certain sony's are common to have bad CRT's. When the screen goes green does the set shut off?
Sep 20, 2009 | Televison & Video
Picture will freeze occasionally for approximately 30 seconds, then return to normal. Switching channels seems to take care of the freezing right away. It is a 53 inch rear projection about 8 years old,...
Good Day,
Try upgrading the Screen refresh rate.Right click on your desktop,properties,in the tab settings select advanced and then select the monitor tab.Select 85-100Hz in refresh rate.
I hope this helps...
Good Luck!
Jun 22, 2009 | Sony KP-53HS30 53" Rear Projection...
Tv shutting off!
replace the high voltage block
the part number is (8-598-955-32)
comen problem for you model number.
regards,
daniel.
Jan 13, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony KP-57WS500 rear projection red screen
sounds like the red crt is bad, you can get a replacement at the following link, if your not sure which one you need just leave them a email with your model number and what youre needing.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Sony KP-53S65 53" Rear Projection...
The dark colos have a lil' green on them...why?
How old is this set? Sounds like a CRT issue, might be able to adjust the G2 control (SCREEN), you will have to pull the bottom pannel off the front and there should be another little 1/4" thick board that comes off with a few screws and then a 6 knob control, turn your color all the way off in the menu and adjust your screen controlls up till you get some overcolor with lines in it and then back down just before the lines (MAKE SURE YOU DEFAULT ALL YOUR USER MENUS) check that you have a black and white picture after adjusting all 3 screen controls like before with the menu color off. If you have a bad CRT it will go again, the CRT may no longer be available, if the set is not too old i.e. 5-8 years old it may be a defect with multiple CRTs.
May 22, 2007 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
607 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
