Question about Nintendo 64 Console
Screen problems every time in hook my 64 to my big screen hd tv , the screen starts shaking but it works fine on my tube tv . same thing with my playstation
  • crevante Feb 05, 2008
    thanks buddy, is there n e thing i can do about it?
    THANKS FOR TAKING TIME TO HELP BE BLESSED
    Master:
    Sergeant:
  • 440 Answers
Cuse old style output not made for new tv 480 i made for tube tv only
Posted on Feb 05, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 05, 2008
    nope
  • nick helpap
    welcome budhey thers one thing but hard to get upcoverting unit by monster sumtime they sell on ebay goes in reg s video and yellow then out hd coumpount cables would help it sum but hard to get
  • nick helpap
    thx for using fix ya
The signal loss along with channel 4 is the only thing on TV screen. The other TV is fine. Checked connections all seem to be fine.
Are you connecting TV receiver box (example: DirecTV receiver); or what is the source? What TV are you using - a new flatscreen / HD or an old big TV? AN old TV - tube type? You have to get to the right input and sometimes it can be blocked by a Vchip parental wring selection.
Nov 16, 2014 | Televison & Video
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Computer display is too big for screen
You need to turn off OVERSCAN in your computer display controls. This will reduce the picture size by 5 to 10% and allow access to the edges. Expect there may be an edge around the screen with nothing in it. Overscan was introduce in TVs to use the whole tube. It is not needed in digital displays. -Ken
Jul 27, 2009 | Televison & Video
Resolution problems/ Game problems
Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
Is the playstation burned out?
Did your cousin ever connect it to an HD tv? If he did, this is a common problem with it. If you operate the PS3 with a normal television set, the ps3 will work fine. But when you connect it to an HD tv and hook up the HDMI cables, the ps3 sets itself to work with HD tv's only. There is a simple fix. a Hard Reset. Call sony customer suuport and tell them that your ps3 doesn't have a menu screen. They will walk you through the steps to restore your system. I would tell what to do myself if I remembered what to do. But regardless, remember this, every time you connect it to an HD tv and want to switch back to a normal tv set, you will have to hard reset the system. Try to remember the sequence the first time so that any other time this happens you'll know what to do.
Best regards,
Gavin93
Aug 18, 2008 | Sony Playstation 3 (PS3) Console
My high definiton is working great and everything is fine except one major thing, which is that there is no sound at all. I would like to know how i might fix this problem.
Good Day, timerwer;
HD is fine but no audio! Not knowing that if you ever had sound, have surround system, hooked to an input or RF, I would suspect that you only have the Green, Blue, and Red cables hooked to your TV and the Audio cables ( red - white ).
If you do; unplug TV (reset, reboot) from A/C outlet for 3 to 5 minutes. If still no work try these suggestions:
1. Make sure the TV's internal speakers are turned 'ON'.
2. Make sure the "BOX" ( cable, sat, u-verse) volume is turned up all the way up.
Good Luck, big IRISH.
Aug 16, 2008 | Televison & Video
Nintendo 64 Console Logo
174 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
