Question about GE WSXH208A Front Load Washer
Ge washer front load
Well the washer has been doing fine, and then for some reason it was taking longer for it to wash a load. It seems like when it should be putting water in to wash or rinse it sits there and makes a humming sound. then it will pause for no reason for several minutes. And when spinning it don't seem to spin as fast. I have unplugged it in hopes that maybe it would reset. what can i do?
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
Can't get the water in the tub & it doesn't spin.
TRY THE LITTLE SWITCH THAT ENGAGES WHEN U SHUT THE LID... MY GE WASHER JUST HAD THE SAME PROBLEM ABOUT A MONTH AGO
Mar 14, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
I just bought this washing machine a week ago,everything seems to be fine but it takes an hour to wash one load of clothes,can I adjust the time to half an hour(my old washing machine only takes 30...
The newer washers are much more gentle on your clothing, but they also take their time to do the job...
Yes, it can be a pain to have it take so long but your clothing will love you for it and will stay nice for you longer...you will also be using less water...
Not much you can do about it as the engineers that know all are the ones that program these things...
heatman101
Jan 21, 2011 | LG WM2010C Front Load Stacked Washer /...
The washer no longer seems to spin... during the spin portion of the cycle it lights up saying it is spinning, but you can see inside that it is not physically spinning. The clothes are left dripping wet...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | GE WSXH208A Front Load Washer
I have a ge front load washer that won't drain i have stuck a coat hanger through the drain hose it doesn't seem to be clogged up.
take front cover off at bottom. there is a fiter that unscrews. be prepared for water to come out. clean filter and replace, good luck.
Jan 29, 2010 | GE WSXH208A Front Load Washer
Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
Nov 17, 2009 | GE WSXH208A Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
GE Front load GCVH6600 Shakes all over the place on spin cycle
Wow...does it sound like it's about to take. You can hear it all over the house even with the door to the room closed? We have the same reason. THis started after a bout of lice in the house and we were doing many loads a day for a while. Help!
Jun 28, 2009 | GE WSXH208A Front Load Washer
Washing takes longer
Reset the options to clear out the current settings.
Mar 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
How do I take the back off?
Unless it a old ge like 15 years or so the back dont come off .. your access the inside for takeing of front panel of the washer
Oct 15, 2007 | GE WWSE5240D Top Load Washer
GE WSXH208A Front Load Washer Logo
43 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
