Question about Lexmark Z645 InkJet Photo Printer
Lexmark Z645 I was given one of these printers by someone and not only were there no cartridges in the printer there are no indications as to which portal the black or the color cartridges go into. Please tell me does the black go into the light green right hand port?
  • fpc10 Sep 15, 2008
    I have a lexmark z645 and my black color will not print. I have installed a new cartrdige. I don't know what else to do.
    Champion:
  • 204 Answers
Usually the black goes in the right pot and the color to the left..There is usually a difference with the cartridges so that they will not be interchagable in the left or right. Also the color on the tops usually match the pot they go in...
Posted on Feb 05, 2008
6ya staff
SOURCE:
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Black line scan
Sir
Checking the print cartridge
Image formation defects are many times the result of print cartridge problems. If there is any doubt, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Or Go To Below Link To Find all The HP Printer Help For Your HP Printer Problems
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-bpl70340-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1390257139382.876444892.492883150
In Case You Need Help Then Follow Us On:
HP Printer Support
Jan 20, 2014 | HP LaserJet 1100a Printer
X3350 printer says incorrect right cartridge
My be ink cartridges has not refilled in proper way.Are you sure your cartridge are compatible with printer?
You can follow the given steps..
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the power button button is not lit, press power button.
  5. Reinsert the print cartridge.
If the error:
  • Does not reappear, the problem has been corrected.
  • Reappears, replace the print cartridge with a new one.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Lexmark X Office Equipment & Supplies
I have a 2600n Does it have a toner portal if so
Most Printers when referencing "toner" are referring to toner cartridges.I haven't seen any that allow you to add any toner as toner is a powder,replace the toner cartridge.Good Luck.
Sep 06, 2009 | Office Equipment & Supplies
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x125
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
I can send faxes but I cant recieve any.
Apr 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark x3470 message "printer cartridge missing"
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Lexmark Z735 InkJet Printer
PRINTER SAYS NO CARTRIDGE CARTRIDGES HAVE BEEN CHANGED
Unplug machine from power outlet. take all carts out. leave cover open. wait 5 min. plug machine to power and close cover. machine will demand carts. reinsert carts and answer question given on display.
If you still have trouble this might be due to the generic carts which have not the right construction. use original carts.
Dec 17, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark Z645 InkJet Photo Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
