Question about Minolta magicolor 2350 Laser Printer
Minolta 2350DL laser printer paper jam that will not clear
Have a severe wad of paper jammed at the rear on the user roller.
The paper wad is on the right rear and have only been able to get small pieces out over last two hours. Trying additional paper only jams up machine. The user roller has some releases which allow the roller to move freely, but the jam remains. Have taken off rear panel in hope of access, but no luck.
  • 29 Answers
You have to take off the roller . :)
Posted on Jun 19, 2008
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Paper jam laser
Could be dirt or a bit of paper stuck to one of the rollers or one of the rollers has jammed. You may have to strip it down a bit to get access to clear foreign objects.
Nov 25, 2013 | Konica Minolta Bizhub C550
Media jam tray 1
Here are a couple of links from the Konica website which provide somes illustrated instructions:
Media Jam Tray 1; Paper Pickup Roller replacement instructions.
Clearing Media Jams
Replacing the pickup rollers seems like a drastic first step. I would check to make sure that the paper being used is suitable for this printer and it is in good consition. You might try a different paper to see if it makes a difference.
Good luck in resolving your issue.
Dec 30, 2010 | Konica Minolta magicolor 2430 DL Laser...
Di151 All-In-One Laser Printer: Minolta Di151 copier. J2 Paper Jam Followed t...
Sensor may be bad, for that jam. cleaned the rollers?
also also mite need to replace the rollers for the draw try this ite you have alegacy Minolta machine Now Konica Minolta
May 15, 2010 | Minolta Di151 All-In-One Laser Printer
Lexmark C710 MFP jams 200.04
Things to try:
1. Look for a piece of paper jammed in the rollers. 95% of the time that is what it is.
2. You have a paperclip or paper wad in a feed roller or gear.
3. The hard and easy way to find the jam is to feed a piece of paper and then before it feeds all the way through unplug power to the machine about the time where it usually jams.(several times may be necessary) Then follow the piece of paper to where it jams to find the location of the clogged paper.
Sep 15, 2009 | Lexmark Optra C710 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Feb 05, 2008 | Konica Minolta magicolor 2430 DL Laser...
Minolta magicolor 2350 Laser Printer Logo
420 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
