Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch nexxt washer is leaking from underneath
My three-year-old Bosch is leaking water/suds from underneath during the final spinning. The leak seems to be from the left corner at the back of the machine. Any ideas?
  • 2 more comments
  • leetlebee Mar 15, 2008
    Our 2005 model nexxt washer is also leaking from the same area.Have checked connections and can't see where it's coming from.
  • djmay May 27, 2008
    My 2004 NEXXT WFMC 3200 Washer also started leaking from underneath the washer on the left side. The seal around the door seems intact and in good condition. I've pulled out the machine to confirm it is leaking from the bottom. All water lines and connections are tight and there is no water apparent near these lines. We use minimum soap and it's not overflowing in the drain. I've moved the machine around in case is wasn't flat on the floor with no change in the amount of water leaking. I'm calling a repair person. I'll post the solution...
  • JennyLCrouch Sep 16, 2008
    Hope someone posts a solution in a hurry, because my Bosch just started doing the same thing........Water leaking from underneath.
  • Anonymous Oct 15, 2008
    Same as said before, leaking then stoping during the spin cycle.
    New Friend:
I found out why mine leaks. In the Bosh design there is a trap molded into the soap dispenser plastic tray. This tray or trap has a wide open path to the inside of the washing machine. We are using the tide pods as a detergent. Two things are going on here. This trap fills up with water immediately when water is cycled into the machine. The second thing is the pods partially dissolve and leave a gunk that blocks the water pathway to the drum. This blockage eventually allows water to pass however when the pressure is high and this blockage is restricting the water level rises and the trap dumps out into the washer panels. This water immediately leaks down and out the bottom. Observation when I disassembled the machine the trap was moldy and stinky. Water stains were running down the inside. Maybe the engineers at Bosch should look into this.
Posted on Apr 07, 2013
  • Bosch Master
  • 744 Answers
leaking.
If the problem is from the door seal, this video will show you a simple way of how to change it on Bosch washing machines, and also how to get the parts.
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
    Sergeant:
  • 351 Answers
Check that the filter is fitted correctly,or is the door seal leaking,it may need cleaning.also might of put to much soap in.hope this helps
Posted on Mar 12, 2008
    Sergeant:
    Champion:
  • 223 Answers
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
Posted on Sep 26, 2008
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
Washer is leaking water out from underneath during cycle
Ours had a problem with water sloshing out of the soap cup during the cycle. The leak appeared under the left front. The fix was to remove the cup and just pour the soap into that section of the drawer. The only problem withthis is that you cannot add soap after you add the soap.
Sep 20, 2011 | Bosch Nexxt 300 Series WFMC2201UC
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from marcone.com
Nov 27, 2010 | GE Dishwashers
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bosch Nexxt 800 series. We have continued problems with the message "suds or blocked pump" we use HE detergent.. what else?  I have drained it once.. it seems that it continues to not pump out the...
Hello,let the machine rest for a while so suds can disappear then unplug the unit for 1 min then plug it back in it should drain by its self if not do not select wash cycle but a spin/drain then you should hear the pump running, if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer, that way if water does not come out you have to access the pump and pinch off the drain hose from the tub and remove the object from the pump, be careful that you don't have a mess with water leaking from the tub good luck.
Thanks
Jun 03, 2010 | Bosch Nexxt 800 WFMC8401UC
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
1,478 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
