Question about Konica Minolta magicolor 2430 DL Laser Printer
Minolta 2350 DL laser printer stuck paper in rear user roller
The unit has a paper wad jammed in the right rear area. The releases let the roller go freely but the jam is not moved, have tried to dig it out which limited success. Took rear off, no access to this roller. Suggestions
  • Anonymous Nov 04, 2008
    PAPER JAMMED UP IN FUSER - HARD TO GET AT TO REMOVE. BROKE SOMETHING WHEN TRYING TO GAIN ACCESS
  • flatearth Nov 18, 2008
    there is a paper jam in the fuser on the left hand side, it seems almost impossible to get to without taking the printer apart, trying to feed more paper through doesn't move it...... help
    Champion:
  • 214 Answers
Sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Posted on Feb 09, 2008
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Paper jam laser
Could be dirt or a bit of paper stuck to one of the rollers or one of the rollers has jammed. You may have to strip it down a bit to get access to clear foreign objects.
Nov 25, 2013 | Konica Minolta Bizhub C550
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Magiccolor 2350. Paper jamed(paper end only)in
Kindly open the delivery door and back side of the printer. Check the space between metalic roller and the plastic with the help of a pin or something thin like ruler. Probably a pin or stappler might be stuck there just remove it. your printer will work fine. Secondly check that if any plastic is burnt or melt over there if so then use something rough to make it plain.
Feb 17, 2010 | Konica Minolta magicolor 2400 Laser...
Paper jam occuring in my minolta qms2350 printer. What can I do? Di I need to and how do I change the rollers? Thanks
I am forwarding a list of manual that will help you with the paper jam issue and also would help you with any future issues related to your printer.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sep 10, 2009 | Minolta magicolor 2350 Laser Printer
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Fuser jam
Drop the cover down and release the 2 green cilps and allow the paper to be pulled out
Oct 08, 2008 | Minolta magicolor 2350 Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
311 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
