Question about Apex Digital PF2725 27" TV
My apex pf2725 tv screen is green
When you turn the tv on the screen is green with lines going across it how do i fix it
    Brigadier General:
  • 6,966 Answers
Your posted/describe symptom seems to be that the green color drive is defective. The "lines going across" are flyback retrace lines brought about by the safe problem.
The corrective procedure would be to replace. In most TV units, color drive are three (3) identical transistors: for the blue, green and red. They are normally located at a small squarish PCB attached to pins of the CRT right at the rear end of the neck. More often, they are heatsinked. Repair should be a straightforward desoldering the defective component and replacing with a new one.
In some versions, color drive is a single IC power pack.
Still, it is also possible that the problem may be due to cold solder on any or all of the pins of the above describe transistor (or IC).
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 05, 2008
I just purchased a universal remote and programmed it to my Apex and I can't get the cable to work I can't get it to go off mono what do I do?
Make sure your TV is set to Cable (Manually), Then with you TV on, hold the cable button down, and keep pressing the power button, till the TV shuts off...this should set your remote to cable mode! When you turn back on, press cable button then power!
You may have to repeat the steps, for the TV to come back on, to re-program your remote!
Hope this Helps!
Sep 10, 2011 | Apex Digital PF2725 27" TV
Need to turn closed captioning off
Hi
Captions will appear at either the top or bottom of the screen while a captioned broadcast is received.
When you select the Text (T1-T4) mode, the TV can receive teletext signal.
When you select "CCD/Text Off ", the CCD / Text function is off.
3)Press the CC button to turn on/off the CCD/Text mode
OK.
Jul 07, 2011 | Apex Digital PF2725 27" TV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
My projection screen has blue and green lines across the screen id do not know how to converge the lines akai screen where do i go to fix it
Hi, thank you for visiti fix ya.
Your tv need convergence ICs service ( replace).
Can you send me model number tv, please?.
Thank you
Jul 25, 2009 | Televison & Video
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
Green lines
This is the convergence amps going bad. You would need some tech experience. But could do it if talked throu.
Sep 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Apex Digital PF2725 27" TV Logo
216 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
