Question about Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF incoming fax problem
I have a problem receiving faxes.
I have a Telstra fax duet separate fax number that worked fine with my previous Samsung MFP on DRPD mode.
Now I have tried it set on:
Auto switching
Fax
Phone
TAM
The problem with auto switching is that if the phone (non-fax) line rings, the fax will answer the call over the conversation.
TAM won't recognise the incoming fax call.
Please tell me I haven't wasted $1300
I used to have this problem too.
I have different phone numbers for my TelstraClear shared fax/phone line, and solved the problem by setting our EPSON CX11NF to fax only.
Now it answers all the calls made to our fax number straight away. The 'phone' number still works perfectly.
It seemed counter-intuitive because I thought the EPSON had to do the thinking, and that if I set it to Fax Only it would try to answer the calls to the 'phone' line as well as to the 'fax' number. But it works because the shared phone/fax line is actually smart enough to sort it out before it gets anywhere near the fax appliance.
Hope my experience helps you too.
Posted on Mar 04, 2008
    Genius:
  • 1,447 Answers
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Posted on Feb 22, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Mar 05, 2008
    Set Incoming to AUTO and DRPD to Normal
6ya staff
SOURCE:
I have a new AT&T DECT6.0 single line answering machine and i'm trying to connect it to my Epson Aculaser fax ( the single phone line is phone/fax), however it's not differentiating the...
If this is a new machine, why haven't you contacted AT&T? Sounds like either it's a configuration problem in the answering machine or it's incompatible with your phone line.
Jul 17, 2011 | Epson ACULASER CX11NF All-In-One Printer
Tip
Free Fax | Free Internet Faxing After setting up your fax you would want to test...
After setting up your fax you would want to test it of course.
Use free internet faxing to check if you can send and receive fax transmission.
on Feb 23, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser CX11NF Printer is offline
you need to go to settings ,then printers then right click from your mouse on your printer ,then put it online..thats it...i hope it will work..
Mar 25, 2010 | Epson ACULASER CX11NF All-In-One Printer
Fax Receives but does not print
You have a known issue with your unit, the unit will require a firmware update. The issue is known to epson and they should fix it under warranty. Contact your local epson service centre or contact epson direct in your country. If they try to charge you, scream loudly at them, advising them that this is a known issue with this model and they are obliged to repair it. You will find they will fix it without too much objection.
Gremlin 11
Oct 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson cx11 outgoing fax problems
This is not an issue with you unit, this is an issue with your phone line. get your service provider to check the line. also remove the line from your fax and put a standard phone on the end, try to make a call and see what happens. if the same result occures, there is an issue with the line and not the fax.
Gremlin11
Sep 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Faxes in memory won't print....
By installing a Dual In-line Memory Module (DIMM), you can increase product memory up to 576 MB. You may need to add memory if you are having difficulty printing large documents
contact epson support line if you want to add memory card/module
Mar 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
Fax issues
yes press fax button and go to setup/ press setup. printer setting and reset menu and select option to reset to default and when you configure settings on your printer for fax feature disconnect line from the back of printer and configure it then when finish reconnect the line and powercycle printer. then test by sending nd ask someone to send you a fax as well.\
make sure incoming mode is set to auto switching and drpd to normal or on
Dec 19, 2007 | Epson ACULASER CX11NF All-In-One Printer
HP d135
Try posting your question in the correct section. This category is for Epson CX11 machines
Dec 04, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
727 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
