Question about Bosch SHU3305 Dishwasher
Bosch dishwasher still some soap left on dishes
Good day,
I have a shu 3302 bosch diswasher and most of the time the glass are stained with soap like. I cleaned them all with CLR and I have replace my upper feed tube because it was cracked. Even at the soap door you can see traces of the soap that stained on the door. I have also done the test by pressing the specific buttons and no light came on at the end of the test meaning that everything is ok. The water seems to drain ok. I am wondering if maybe the water level is not high enough. when I check the water level in the middle of t he cycle I have about 5/8" inch deep. When I open the door the pressure seem fine and both the top and bottom rotating spay are working fine.
Can you help me with this.
Regards
Thanks
Guy Laperriere
guylap@royaume.com
  • Anonymous Sep 06, 2008
    Soap not rinsing off, dishes still dirty too
  • Bosch Master
  • 17,155 Answers
Most of the causes of the problem that you are describing are related to the way the dishes are loaded in the unit. To test this, run it empty and see if the dish soap dissipates.
Posted on Mar 17, 2017
catriver
  • 878 Answers
SOURCE: Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Posted on Sep 03, 2006
SOURCE: bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Posted on Jan 13, 2009
  • 423 Answers
SOURCE: My Bosch shu 42 just
When the heating element fails on dishwashers, the wash cycle water can not be heated high enough the activate the DW detergent powder.
Replacing the heating element should fix you right up.
Also, resist the temptation to switch the a cheap, generic powder. A brand name e.g. Electrosol or Cascade powder is proven to work well. The ultra-cheap powder will leave white patches on the dishes and it will not dissolve completely, even when the heating element is working properly.
Good Luck!
Posted on May 04, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Posted on Aug 22, 2009
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Soap is left on the dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 25, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Very filmy looking glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 31, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU3305 Dishwasher Logo
67 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
