Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Red, Green, and blue
First I replace the ICS t.v. still showed red, blue, green. Took it back apart found the upper 5amp fuse on the G board bad replace it. Put the t.v. back together, Still didn't work. Took it back apart to find the same 5 amp fuse blown also, a 3.15 amp fuse is blown. My next step is thowning the t.v. in the trash cause i'm not payin $400 to get it fix. Can someone please help me!
  • 3 more comments
  • lilrere Feb 05, 2008
    so so when i ohm the ics pins i should not get any continuity between them
  • lilrere Feb 06, 2008
    The part number for the IC's is STK392-560 same as the original ones.
  • Anonymous Feb 29, 2008
    Sony KP-46WT500 46"rear proj. has an hourglass effect happenning at top and bottom. Green lines in pic that show more so in darker scenes and a blurry effect or ghosting, in red,blue and green.
  • Vista Electronics May 11, 2010
    Do a pin-by-pin comparison of one IC to the other...they should
    check very close to the same on your ohmmeter......
    What do you read?..............T.
    What part # and quality IC's did you use ?...........T.
I have also replace % amp fuse on g board my tv works for day and then fuse again, It happen two time any Suggestion.
Posted on Feb 28, 2008
  • Anonymous Feb 28, 2008
    I mean after i have replace 5 Amp fuse on G board and both ic on D board my tv works perfect for one day and then 5 amp fuse blow again it happen two times how do i solve this problem.
  • 113 Answers
Those fuses usally blow when the ics are shorted. Are you sure that you were careful soldering them in and did not have any bridges? Also you make look for some resistors that have changed value on you after all of this.
Posted on Feb 05, 2008
  • Anonymous Feb 05, 2008
    Well that all depends to because some of the pins are ground so those would have it. You just need to look at them and see if you can see anything where you could have bridged the solder connections. Check PS 8001 and 8002 make sure they are not open hopefully this gets you closer.
    Master:
    Sergeant:
  • 440 Answers
Sell it on ebay as broke they go for 100 just a idea look like u tryed alot
6ya staff
SOURCE:
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
The tv shows only red and blue it projects three
You need to replace Both STK ICs . They are Big Black ICs and will have PN# on them
example STK392-110
Mats has ICs 1-800-628-1118
Also check the Pico Fuse in Front and back Of ICs they look like resistors ,But will be Green or Yellow 5amp, 6amp, 7amp.
Feb 22, 2011 | Sony KP-51HW40 51" Rear Projection...
Although tv is showing picture the colours only showing background etc are green and blue
Hello
Your TVs red colour output section has the trouble. There is no red output at the red cathode of the picture tube. The red, green, and blue output sections are on the picture tube base board. In some Philips model, these will be consists of transistors, and some has an IC or Tree ICs for three colour output used. You just open your TV, measure the voltages at these three cahodes. There will be markings on the printed circuit board for these cathodes marked as [Rk,Bk and Gk].
In your TVs case the voltage at the Rk marked pin will be higher that the other two cathodes. This can be caused by an open drive transistor or an Ic whichever may ysed there. If it is transistor, just replace it with a same type and number, as in the ace of ICs the related Ic, must be replaced. If only one Ic is uded for red, green and blue outputs, that Ic must be replaced.
If you need any more assistance, feel free to get me through Fixya. Ok.
Dec 01, 2010 | Philips CCB130AT 13 in. Combo
I have a rear projection tv model number kp-61v90 i have no picture sound works menu shows also at the very top of screen there are lines red blue and green help me make this repair please
From what you have said , Replace both of your STK ICs they are big black ICs will have part number on them example STK392-110
Go by the number printed on them if they are 110s use the 180s they are better ICs Mats has them for $10.95 each 1-800-628-1118
Also go to this website/use Google Encompass Parts Distrubtion
1-800-638-3328 sometimes they will have free service manuals you can print out.
Another thing you need to CK pico fuses they will look like resistors only they are green or yellow 5amp/ 6amp fuses Look in front of ICs and some are located behind ICs.
Mar 17, 2010 | Televison & Video
My screen is green and red, kinda like a 3d showing
The problem with the unit is convergence.Remove convergence output board then replace IC2701 and IC2702 both of them are STK-392-120,After replacing ics you have to go into the menu of unit to adjust convergence.Align the red ontop the green then blue ontop the green.
Oct 03, 2009 | Zenith R57W46 57" Rear Projection...
Started see red and green in the tv picture and a funny looking line in upper left corner. words on screen are shaddowed with red and green
Replace both of your STK convergence ICs will have part number on them also ck pico fuses around ICs they will look green or yellow like resistors, but are Fuses.STK392-110 example.
Sep 16, 2009 | Sony KP-57WS500 57" Rear Projection...
Works but prdominantly green, can't ajust with color controls
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Mar 07, 2009 | Sharp Notevision XG-NV6XU Multimedia...
How do i center the colors, red, blue and green?
Replace Both of your convergence ICs STKs, big black ICs.
STK392-560, also CK pico fuses around ics you may have 1or2 bad .
HAPPY NEW YEAR!
Jan 01, 2009 | Sony KP-61HS10 61" Rear Projection...
Cant tune red bulb
Check pico fuses F9A04 and F9A05 if either one of those picos are open it means the convergence Ics are bad along with the picos. Your set uses two STK392-570 ICs and the two picos are both 5amp picos. You can get replacement parts and installation instructions at the following link.
http://servicemanuals.vstore.ca/
The pico fuses are located on the second board from the right heres a pic of where they are.b86c4db.jpg
Nov 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence ICs
the green is half controlled by half of each of the convergence Ics meaning green horizontal is controled along with the red and green vertcal is controlled along with the blue Ics. So if you have replaced both Convergencs ICs the problem is most likely a resistor that is in the green circuit. You will need a schematic to locate which resistors are in the green vertical and horizontal convergence circuit
Jun 07, 2008 | Toshiba 55H70 55" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
