Philps CD 880 tray switch
Does anyone know where I can get the switch that mounts on the upper rear portion of the CD tray mechanism and is actuated by the door closing? This is a Philips CD880 Player with many mods so I'd like to save it if possible.
Thanks,
Dan
  • dgoldsbe Feb 05, 2008
    Thanks joebert. The plastic tab that gets pressed backward to force the switch contacts to close has broken. It is so thin that gluing it back in place is not an option. I can't seem to find a way to stick anything it is place. Wedging something results in it falling out. Does anyone know of a place with used parts or maybe old units?
  • dgoldsbe Feb 07, 2008
    Looking for a replacement switch not the existing one.
This can be fixed by making a small tray to hold a new switch like this;
http://www.isplc2006.org/b2b/pics/Micro_Switch.jpg
If you remove the old switch and use a custom plastic 'platform' to hold the new switch (where the old switch used to be) you will have a far stronger and better (the arm is metal not plastic) mechanism.
It's pretty simple and the tray can be screwed into the existing holes with the trigger arm hitting the same tray ridge. Some experimentation is needed - but for $4 (for the new switch) and an hour making the mount, it's worth it!
I've done it - it works and saved this player!
Posted on Dec 26, 2008
Most philips players have this switch fitted. Find a junker and remove the switch from it.
The machine can work without the front switch working though it would no longer have the "push close" function. If that is never used, swap switches between front and rear while you look for a replacement..
Posted on Jul 19, 2008
  • 29 Answers
Look something that protrudes at its cover that get inside a hole in the cd tray, it is the one that pushes the switch.
Posted on Feb 05, 2008
6ya staff
SOURCE:
1998 ford taurus door llock actuator
More info needed. Is this a front door or a rear door? If a front door, you need to remove the plastic interior trim panel for access. With the interior panel removed, temporarily reinstall the window switch to raise the window glass. Look inside the door at the lower rear corner. You will see the lock actuator there. It's mounted on a steel U shaped bracket. It has a black rubber boot over it and a rod going up to the door latch. You may need to remove the bolt holding the steel U channel which guides the rear of the window, for improved access to the lock actuator. Unsnap the retaining clip for that rod at the latch mechanism. The U shaped bracket is riveted into the door frame. You will need a 3/16" or 1/4" cobalt drill bit [available at Ace Hardware] to drill out the retaining rivet(s). Partially remove the actuator for better access to the electrical connector. Disconnect the electrical connector and remove the actuator. Reverse this process to install the new actuator. You can use a Nyloc nut, washers and a bolt to mount the new actuator if you don't have a rivet gun and the proper sized rivet(s) to remount the new actuator.
May 04, 2014 | 1998 Ford Taurus
DVD player will not work.door open then closes then open again
hi you have to check weather the micro switch at the cd tray has contact or get trigger during the tray get close.if not the door will open again.the micro switch is found at the rear portion of the loading tray, it was connected with two wires going to the main board.just let me know if you need further assistance good day.
Nov 09, 2012 | Televison & Video
What is the procedure to changing an keyed ignition lock?
Removal
Disconnect the negative battery cable with the proper size wrench and place away from the battery.
Insert the key into the ignition lock cylinder and turn the key to the run position.
Remove the steering column cover on a tilt steering wheel model by pressing the upper and lower section of the cover together and pulling free from the mounting plate. Remove the steering column covers on a non tilt steering wheel model by using a Philips screwdriver and unscrewing the mounting screws.
Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
Press the ignition switch actuator pin by pushing a small screw driver into the key lock cylinder, while doing this pull the ignition switch out of the ignition switch housing.
Installation
Insert the new key into the new ignition switch and turn the key to the run position. Insert the new ignition switch into the ignition switch housing. Wiggle the switch back and forth until the actuator pin mounting hole is aligned and falls into place.
Install the electrical connector back into the connector housing by pressing it in with your hands.
Place the steering column covers back onto the non tilt steering wheel and insert mounting screws. Tighten screws using a Philips screwdriver. Place the steering column covers over the tilt steering wheel and press the upper and lower portion together to snap covers back into the mounting plate.
Pull on the ignition key to ensure switch is locked into place. Turn key to the "off" position and remove the key. Insert the key and start the vehicle.
Hope these help.
Jan 28, 2011 | 1992 Ford Crown Victoria
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
I can't get the rod that connects the key lock and door latch in the right position to work correctly.
  • Disconnect the negative battery cable with the proper size wrench and place away from the battery.
  • 2 Remove the steering column cover on a tilt steering wheel model by pressing the upper and lower section of the cover together and pulling free from the mounting plate. Remove the steering column covers on a non tilt steering wheel model by using a Philips screwdriver and unscrewing the mounting screws.
  • 3 Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
  • Installation
  • 1 Insert the new key into the new ignition switch and turn the key to the run position. Insert the new ignition switch into the ignition switch housing. Wiggle the switch back and forth until the actuator pin mounting hole is aligned and falls into place.
  • 2 Install the electrical connector back into the connector housing by pressing it in with your hands.
  • 3 Place the steering column covers back onto the non tilt steering wheel and insert mounting screws. Tighten screws using a Philips screwdriver. Place the steering column covers over the tilt steering wheel and press the upper and lower portion together to snap covers back into the mounting plate.
  • 4 Pull on the ignition key to ensure switch is locked into place. Turn key to the "off" position and remove the key. Insert the key and start the vehicle.
  • hope this helps you
    Dec 21, 2010 | Ford F-350 Cars & Trucks
    How to replace the shocks on my 2000 Mazda 626
    REMOVE**** FRONT SHOCKS, FIRST OF ALL.SUPPORT THE LOWER CONTROL ARM WITH A JACK,REMOVE FRONT WHEEL, REMOVE BRAKE HOSE AND ABS SENSOR HARNESS TO THE STRUT BOLTS OR CLIPS,REMOVE ACTUATOR FROM TOP OF THE STRUT,IF EQUIPPED WITH AUTOMATIC ADJUSTING SUSPENSION. PAINT ALIGNMENT MARKS ON THE UPPER STRUT MOUNTING BLOCK AND STRUT TOWER AND ON THE LOWER STRUT MOUNT TO STEERING KNUCKLE SO THAT CAN BE REINSTALLED IN THE SAME POSITION. REMOVE UPPER STRUT MOUNTING NUTS, REMOVE THE STRUT TO KNUCKLE BOLTS,REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT INTO THE STRUT TOWER ALIGNING THE PAINT MARKS MADE DURING REMOVAL.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 34 - 46 FT LBS. INSTALL STRUT TO KNUCKLE BOLTS TIGHTEN TO 55 - 61 FT LBS. INSTALL ACTUATOR AND ENGAGE THE ELECTRICAL CONNECTOR IF EQUIPPED WITH AAS. INSTALL BRAKE HOSE AND ABS SENSOR HARNESS CLIPS OR BOLTS.INSTALL WHEEL AND CHECK ADJUST THE FRONT END ALIGNMENT. TO ( REPLACE REAR SHOCKS ) REMOVE REAR WHEELS, REMOVE REAR PACKAGE TRIM. REMOVE SPEED SENSOR HARNESS, REMOVE TOP STRUT NUTS,THE SUSPENSION WILL DROP WHEN THE WEIGHT LIFTS OFF THE WHEELS. REMOVE BOTTOM STRUT BOLTS.REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT ASSEMBLY, INSTALL BOTTOM STRUT MOUNT BOLTS AND TIGHTEN TO 55 - 61 FT LBS.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 33 - 46 FT LBS. INSTALL SPEED SENSOR HARNESS.INSTALL REAR PACKAGE TRIM. INSTALL REAR WHEELS.
    Sep 22, 2010 | Mazda 626 Cars & Trucks
    Vacuum will not turn off
    (1) Please check the four screws that mount the upper handle to the lower handle. If they are not tight, the actuation of the switch may not be adequate.
    (2) Remove the four screws and the upper handle. you will see the rocker switch in the pocket. If it turns ON/OFF with your finger while plugged in, then switch is OK and you have mechanical activation issue.
    Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
    Upper level of dishwasher isn't cleaning, looks like the upper arm isn't spinning, no water delivery, how do fix this?
    look at the top back portion inside dishwasher. when you slide that top tray back it connects to the water line to spin the spraying mechanism. ensure that is not stuck or lost rubber boot.
    May 24, 2009 | Dishwashers
    My transfer case is permanently engaged but no 4 wheel drive...
    2 common problems that cause this are the vacuum switch on the transfer case and the vacuum actuator mounted under the battery tray. When the switch on the transfer case goes bad it pulls fluid out of the transfer case and pumps it into the actuator and destroys it. The switch only costs about $15 and are usually stocked at major auto parts stores. The actuator ranges from about $50 to $120 and most of the time need to be ordered. If you reach under the battery tray with the 4wd engaged and follow the cable you will feel the end of the actuator, make sure that it is pulling back. If not either the switch or actuator or both are bad. Hope this helps.
    Jan 08, 2009 | 1999 Chevrolet Blazer
    Phillips CD Tray Switch
    Dan, I know its been a couple of years since you posted this question, but i just stumbled upon this. Did you ever find the parts you needed? I have a CD880 that shows disc error all the time. This unit has been boxed up for the last 4 years and has hardly ever been used. I have no idea why the error message issue is happening. However, I have not been able to find an answer to my problem in my area. If you are still looking for a spare CD880 for parts I know that mine would be a good choice. Let me know if you may want to check it out.
    Michael
    Feb 05, 2008 | Audio Players & Recorders
    237 people viewed this question
     Grubhead
    Grubhead
    Marvin
    Marvin
